is this the simplest box calculator on the net ? - diyAudio
Old 17th February 2005, 02:15 PM   #1
zuki is offline zuki  United States
Default is this the simplest box calculator on the net ?
i searched for calculators and some need even more info than this one.
and i don't have all the info on a driver for even linear calc.
http://www.linearteam.dk/default.aspx?pageid=newdriver
Old 17th February 2005, 05:04 PM   #2
simon5 is offline simon5  Canada
Yes this is the most simple calculator on the net.
You need only Vas, Qts and Fs.
What is the driver you're looking for information about?
DIYaudio for President !
Old 17th February 2005, 05:50 PM   #3
12" Subwoofer -
Peak Power Handling: 2200 watts per pair / 1100 watts each
RMS Power Handling: 900 watts per pair / 450 watts each
Dual 6 ohm voice coils
100 oz. Magnet
2.5" Kapton Voice Coil
Fs: 20.9 Hz
VAS: 5.73 Cubic ft.
XMAX: 11.1mm
SPL: 88dB
Old 18th February 2005, 06:19 AM   #4
how can i find qts ?
Old 18th February 2005, 03:28 PM   #5
I can't find anywhere information on the net about this subwoofer, you should try sending a email to JL Audio or the seller or measure it yourself...
Old 18th February 2005, 03:42 PM   #6
I finally found the information for you...
This woofer is in the JL Audio 12" Discontinued driver line.
It's a 12W6AE
SUBWOOFER: 12W6AE
Free Air Resonance (Fs): 20.9 Hz
Electrical "Q" (Qes): 0.462
Mechanical "Q" (Qms): 6.897
Total Speaker "Q" (Qts): 0.433
Equiv. Compliance (Vas): 5.73 ft^3 or 162.3 litres
One-way, Linear Excursion (Xmax): 0.438 in or 11.1 mm
Efficiency (1W/1m): 86.9 dB SPL
Effective Piston Area (Sd): 82.5 in^2 or 0.0532 m^2
DC Resistance (Re): 10.8 ohms
Nominal Impedance: Dual 6 ohms
Power Handling (continuous): 300W
Mounting Depth: 5.625 in or 143 mm
Mounting Hole Diameter: 11.0625 in or 281 mm
Driver Displacement: 0.085 ft^3 or 2.4 litres
Old 18th February 2005, 05:37 PM   #7
the speaker is a jl audio copy.
made by precision audio and called a J W
maybe it not as good or does not measure correctly.
thank you
a jl12w6 is 350.00 msrp for 1
the jw 12 is 78.00 a pair
that is why i wanted to use them
looking for a diamond for no money
Simplest OTL? leadbelly Tubes / Valves 30 20th July 2007 10:55 AM
simplest sub amp odysseybmx414 Solid State 2 28th December 2005 04:24 AM
Simplest DAC audioPT Digital Source 1 19th April 2003 04:06 AM
Looking for the simplest DAC ever... martioz Digital Source 4 7th March 2003 03:09 PM
Simplest possible Mr. Triatic Solid State 7 17th October 2002 09:11 AM
Copyright ©1999-2017 diyAudio
