car sub for in house
Old 20th January 2005, 10:55 PM   #1
merlinx76 is offline merlinx76  Canada
Default car sub for in house
I have been looking at this sub to use at home. I plan to use a pair of these in a low Q sealed box. It models very closely to a Tempest. The sub is an Elemental Designs 16kv.2. I am thinking of chosing this over the Tempest for 2 reasons... 1 - its a little cheaper (plus an extra 10% off when you buy 2) and 2 - I can get away with a smaller box (without needing an Linkwitz Transform).
Is there any reason why you think this would be a bad choice?
SPECS:
Qts .32
Qms 3.60
Qes .35
Re 3.7
Vas (Liter) 329.00
Sd (cm^2) 840
Fs (Hz) 19.9
Bl 16.00
MMd 179.00
MMs 193.00
Xmax 16.1mm
The following graph represents the SPL I can achieve with 250W in their respective enclosures. Both subs get very close to Xmax at about 18hz or so (with the 12hz HPF included on the amp I plan to use). Will 250W really get these subs to Xmax in these relatively large enclosures?
Old 20th January 2005, 11:18 PM   #2
xstephanx is offline xstephanx  Canada
Send a message via MSN to xstephanx
actually, that looks like it models very well. This interests me if its cheaper than a tempest. Could be another new steal of a bargain for DIY HT drivers.
Id say go for it, it doesnt mdel to much different from a tempest, ahs a bit more sd a bit less xmax, and should sounds pretty similar and hit similar SPL levels.
Old 24th January 2005, 04:59 AM   #3
simon5 is offline simon5  Canada
Default Re: car sub for in house
Yes, in large enclosures you will reach Xmax quite fast, 250W is enough.
Even a Tempest will reach Xmax with 250W in a 5,5 feet sealed enclosure at around 19 Hz.
DIYaudio for President !
Old 25th February 2005, 03:00 PM   #4
I did end up buying 2 of these and I'd have to say I'm very pleased. I really think these should be considered more often for budget subs.
I am sure they are in the same league as Tempest and they are cheaper... USA or Canada for $243/pair $135/each shipping incl.
I am running them in 4 cu. Ft sealed each (with EQ). I currently have them on 350W each and for this enclosure they could maybe take a little more. They come in 2 or 4 ohm DVC. I have dual 4 ohms and a PA amp that's 2 ohm stable in stereo mode but am running in series right now. I could get more if I thought I needed it.
If I only had a Tempest to compare...
Old 27th February 2005, 11:28 AM   #5
skyraider is offline skyraider  Malaysia
What model are those? What is the diameter size?
Old 27th February 2005, 04:19 PM   #6
16kv.2 its a 15"
linky
All Elemental Designs' subs feature what they call Co-Linear technology... Increased drive unit efficiency and reliability through exacting motor design harnessing the centrifugal magnetic field longer without power degredation. Superior electro-magnet power distrobution and application of applied energy resulting in superior sound quality and output.
I wonder if it's comparable to Adire's XBL^2. They don't offer graphs of BL vs. excursion like Adire does to back up their claims though. Even still, they are cheaper than Adire's non-XBL drivers.
Old 27th February 2005, 07:33 PM   #7
jjdche is offline jjdche  United States
Interesting....that is quite a good deal.
car sub for in houseHide this!Advertise here!
pcb fab house Bengali Parts 4 8th May 2008 08:30 PM
Any DJ’s in the house? Netlist Everything Else 23 8th March 2008 11:43 AM
Using a car amp in the house?? imperfectcircle Solid State 8 9th February 2007 04:25 AM
