12" XLS with 2 bxp10 PRs
Old 19th January 2005, 02:43 PM   #1
rarya is offline rarya  United States
Default 12" XLS with 2 bxp10 PRs
Hi all,
I would like to know if someone could review this design. I am planning on using 2 BXP10" PR with 1 Peerless 12" XLS. I modeled the design in Unibox in 40 Liters box and total weight of 600 grams. The results will be flat to 25Hz and an F3 at 22.
The specs for the PR: Sd 308 cm^2, Fp 16 Hz, Mms 226 gr, Cms 0.43 mm/N, Vap 56 l, Q 3, Xsus 22mm one way.
bxp10 Specs
I will also be using the 500 watt PE plate amp.
Thanks in advance for your input
Rajiv
12" XLS with 2 bxp10 PRsHide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
"Void free" or "no core gaps" plywood rick57 Multi-Way 6 14th March 2007 02:09 PM
Fostex "rated input" and "music power" hugz Full Range 12 16th March 2006 05:33 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
Copyright ©1999-2017 diyAudio
