Subwoofer for 50-60L enclosure...... help! - diyAudio
Old 13th January 2005, 02:50 PM   #1
Mutley666's Avatar
Exclamation Subwoofer for 50-60L enclosure...... help!
I'm planning to build 2 subwoofers for my HT and Music system, they will be built into cabinets and therefore cannot be bigger that 60L (I would perfer 50L though!).
Does anyone have any suggestions as to which Subwoofers would suit this application, bearing in mind I don't wanna spend to much and I live in the UK.
Old 13th January 2005, 03:24 PM   #2
Did it Himself
richie00boy's Avatar
What are the dimensions of the room and how loud do you like it? You might find that a budget speaker just won't cut it for HT. This is the problem I have with my 60 litre vented 12 inch with a fair bit of EQ. Admittedly I have it fairly loud and could cut down on the EQ a little, but I'm upgrading to 'proper' drive units now at over 100 each and using 2 of them. Not to mention the power required to drive them...
Old 13th January 2005, 05:18 PM   #3
Mutley666's Avatar
The room is approx 4.5m X 5.0m, but I live in a appartment so it can't be too loud anyway.
I don't mind spending between 120 & 180, but that is all my budget will allow.
As to powering them...... I already have 2 x 200W RMS amplifier modules from BK Electronics ready and waiting.
I have looked at the Peerless XLS 10", but I'm not to impressed with the resulting graphs in WinISD.
Old 13th January 2005, 06:53 PM   #4
Did it Himself
As you already have an amp that should be just about OK then you should be able to do it with some half-decent drivers at least Do not worry too much about what you saw in WinISD. I bet you modeled a sealed box which with these drivers with their low Qts will look terrible. Also, you will get some gain from the room if it does not have any open points, beginning around 344 / (5 x 2) = 34 Hz.
The XLS10 requires a small, assisted box -- which dictates a passive radiator -- to get the best out of it. Also look at the LAB12 BK has. Shiva is available in the UK at about 125 and Shadow Works and Nightfire are both nice companies.
Subwoofer Enclosure jumpus Subwoofers 3 22nd May 2007 02:07 PM
Subwoofer enclosure lawbadman Swap Meet 5 5th May 2006 12:20 AM
subwoofer enclosure danbmellow Subwoofers 7 12th August 2004 08:13 PM
Subwoofer Enclosure ? Ford_V6 Subwoofers 2 10th June 2003 08:37 PM
Copyright 1999-2017 diyAudio
