In terms of output, what is considered above average, to the average person that is?
Would a Maelstrom in a 22" sealed cube with a 1000 watt PE subwoofer amp do the trick? This could be built for about $800 it seems. Or would it take a Tumult in an Adire reference design to do the trick? |
#2 |
IMO an undistorted output of 120dB at 20Hz
and it can be done cheaply and easily-you can have world class quantity and quality-but you have to be willing to cut a hole in your house somewhere... I don't know why IB subwoofers are rarely mentioned at this forum-everybody seems to be obsessed with smaller,more complex and lower performance designs -maybe they're just doing it for fun and aren't as worried about the outcome but I prefer to get the most for my money that I can
"The appreciation of music is subjective.The reproduction of music isn't."-Bill Dudleston |
#3 |
I am willing to listen, please outline such an IB setup.
#4 |
Here's a brief overhead view of an installation I did in the mid 70's.
This is an infinite baffle because the unusual wall keeps the rear wave of the woofers from the listening room. The woofers are mounted in the wall just behind the mid/hf units (blue boxes). There was one 12" woofer per side. X represents the listener. Although originally not used in this installation because we didn't know much about standing waves at the time, "trap" represents tightly compressed fiberglass which will get rid of the axial standing waves along the length of the room. Probably not applicable to your situation but this gives you the general idea of an infinite baffle installation. When the volume behind the woofers is many times Vas, you have an infinite baffle. The garage could be replaced by an attic, crawlspace or large closet. 4 12" woofers per side would be jaw dropping. Of course it needs to be bi-amped. You need to select woofers with a Qt between .5 and .7 |
#5 |
Cult of the Infinately Baffled
This Site will give you a good grounding on IB subwoffers. Very cool. Doug |
#6 |
From the messages on the "Cult of the Infinitely Baffled" is seems this is setup is superior to conventional Subs if you have the necessary space, ie basement or suitable attic?
Considering I am looking to WOW my friends and "feel" movies like Terminator, is an IB arrangement practical compared to a Maelstrom setup for around $1000? My house has a suitable basement and attic and I am not afraid to cut holes in either! My living room is approximately 20x16. Thanks for the links and quality information. |
#7 |
If you want to use the Maelstrom, why a 22" cube? Use it in a IB setup or a very huge vented box since you have the space for it.
DIYaudio for President ! |
#8 |
The dayton IB drivers work great
#9 | |
#10 |
Low WAF
| Is this considered a horn speaker? | audiophile36 | Full Range | 7 | 5th November 2006 05:22 PM |
| why is oversampling in CD players considered bad? | wa2ise | Digital Source | 61 | 30th October 2005 01:41 PM |
| What Vd would be considered good? | scott beavers | Full Range | 1 | 26th October 2005 08:45 AM |
| Page generated in 0.11146 seconds (72.12% PHP - 27.88% MySQL) with 11 queries |
