3rd order hi-pass
3rd order hi-pass
Old 6th December 2004, 02:54 PM   #1
keyser is offline keyser  Netherlands
keyser's Avatar
Default 3rd order hi-pass
hi guys,
does any one of you know how to make a 3rd order high-pass filter at 40 hertz, and one at 50 hertz?
my plate-amp doesn't feature a high-pass, so i guess i should build one myself. thanks!
Old 6th December 2004, 05:33 PM   #2
BassAwdyO is offline BassAwdyO  United States
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
Do you want passive or active? I'd suggest active, as I've heard they dont have some of the phase problemes that passive filters have, and when you add inductors and capacitors to the speaker circuit, you lose a bit of power. WinISD has circuitry design calculators, but only has designs for 1st and 2nd order filters. I'm no expert, but I'd say you could wire a 1st and 2nd order active filter in series and get a 3rd order filter. The first filter would cut down to 6db/octave, then the second filter would cut down another 12db/octave giving you a total of 18db/octave. There might be some problem with that I dont know about. There's probably a design using a single transistor.
The golden rule of DIY:
Build nice, or build twice!
Old 7th December 2004, 12:20 AM   #3
keyser's Avatar
thanks.
i want to use an active filter (low-level) between plate-amp and poweramp. Wouldn't it be better to make a good 3rd order filter from the start?
Old 7th December 2004, 01:30 AM   #4
simon5 is offline simon5  Canada
I found a webpage that calculate everything, you might want to try it out.
http://ccs.exl.info/calc_cr.html
DIYaudio for President !
Old 7th December 2004, 02:13 AM   #5
xplod1236 is offline xplod1236  United States
xplod1236's Avatar
Send a message via AIM to xplod1236
try filter pro from texas instruments
3rd order hi-passHide this!Advertise here!
supravox 4th order band pass sub_arctor Subwoofers 10 10th April 2008 08:53 PM
1st order low-pass filter, which cap ? Thmartin Parts 4 17th November 2005 09:37 AM
6th order band pass. what drivers? noyzmunky Subwoofers 3 26th July 2005 04:16 AM
Aleph P.17 1st order high pass filter Ignatz Pass Labs 2 30th October 2002 07:56 PM
Copyright ©1999-2017 diyAudio
