Dipole - 4 ohm in series or 8 ohm in parallel? - diyAudio
Old 1st December 2004, 07:25 PM   #1
cheesehead's Avatar
Default Dipole - 4 ohm in series or 8 ohm in parallel?
Hi everyone,
I'm thinking of building a couple of W-frame dipole subs using Custom Acoustic's IB15 sub - $100 each.
I don't have an amp yet... but it won't likely be a plate amp, which would take up a little more room in the W-frame (SAF is important). I will probably power them initially using a generic SS amp/receiver I've got lying around, with a 11-band equalizer, running each sub off one amp channel.
SO:
I can order the IB15's in 4 or 8 ohm versions. Assuming my amp will handle either 4 or 8 ohm load, am I better off to order 4 ohm and wire them in series (giving me a 8 ohm load per sub) or get 8 ohm and wire them parallel (4 ohm total load per sub)?
Thx!!
Old 1st December 2004, 07:53 PM   #2
Bill Fitzpatrick's Avatar
No contest. 8's in parallel.
What would you do? series/parallel MtnBob Multi-Way 22 23rd August 2016 01:41 AM
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 19th February 2014 11:16 PM
series or parallel? medicman Tubes / Valves 5 22nd January 2009 04:42 PM
series vs parallel SPL? 2litre Multi-Way 16 22nd February 2006 09:58 AM
Copyright 1999-2017 diyAudio
