How is the Nao woofer preforming?
Old 1st December 2004, 12:19 PM   #1
icebear is offline icebear  Norway
Default How is the Nao woofer preforming?
Can anybody say anything aboute the Nao woofersystem?
I have a Eminence Gamma 12 in a closed box (x2) aboute the size of the Nao. I tougth cutting the back of the case and make it open in that direction. It 's going to be used with the Bastani Prometheus open baffle speaker. How do the Nao compare to a nice H-baffle?
regards
Bjørn
Old 1st December 2004, 01:27 PM   #2
rick57 is offline rick57
I recall a post at http://www.madisound.com/cgi-bin/discuss.cgi that it didn't sound too different from an Orion.
I've heard the Orion bass and its very natural clear and impressive.
Old 1st December 2004, 09:42 PM   #3
Default It works grat :-)
I have changed my box'es so they are open like the Nao. It works better than the sealed box I think. The dipol bass is so much more in the room, and not in the box. I'm not shure aboute the settings in my active x-over. I now have +3 dB at 30 hz and are cutting at 100 hz - 24db/oct. Have to use it for a while to figure it out.
Bjørn
Old 1st December 2004, 10:01 PM   #4
You probably know that the key factor is baffle width, relative to wavelength; and that U frames are basically just a close realtive to dipoles.
+3 dB at 30 Hz sounds too modest. If you read the theory on dipoles at www.linwitzlab.com, IIRC SL suggests 12 dB/ octave boost.
Richard
Old 1st December 2004, 10:30 PM   #5
How are you determining appropriate boost?
I’m getting SoundEasy in the post in 3-4 days, which you may know now has U frame modelling capability written by John K.
It will take me a little time to get the hang of it, but as I’m going to model & build a U frame myself, if you like, I’d be happy to model yours.
Cheers
How is the Nao woofer preforming?Hide this!Advertise here!
4 ohm or 8 ohm woofer in 2 way mmgando Multi-Way 0 4th December 2007 07:14 AM
Do I still need a woofer? fossilfool Subwoofers 3 17th May 2007 12:16 PM
diy sub-woofer takashi Subwoofers 3 19th August 2003 09:16 PM
the best mid-woofer? joz Multi-Way 4 19th March 2003 08:19 AM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Copyright ©1999-2017 diyAudio
