Xmax
Xmax
Old 1st December 2004, 02:31 AM   #11
BAM is offline BAM
Send a message via AIM to BAM
That driver's use is probably as the woofer on a 3 way speaker. It can match up with high-sensitivity midranges and tweeters, and the extra Xmech is so if you overdrive it, it won't bottom out, just stop going and start sounding like flub.
Old 1st December 2004, 04:37 AM   #12
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Xmax
It's kind of an odd duck.
Take a look at it's frequency response-very smooth, and with a notch filter you can have a crossover up to 3,500 Hz!
At first, I thought this high efficiency woofer might be made for tube fans, who need high efficiency to offset lower power. Adn I thought that the smooth midrange response might well be for high efficiency two way designs where a horn comes down to 1,000 Hz or even lower.
But then I see that it is 4 ohms. I think most tube fans like impedances higher than that.
Red line is 3 cu ft, ported, tuned to 30 Hz.
Blue line is 2.25 cu ft, sealed, Qts = 0.7
I think it is meant for high efficiency enclosures, where the builder is more interested in efficiency than small box size.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 1st December 2004, 04:39 AM   #13
Wizard of Kelts
Xmax
And here is the frequency response. A notch filter could take the crossover frequency up to 3,500 Hz! For a 12. Actually, I doubt that you would want to cross over anywhere near that high.
-Anonymous
XmaxHide this!Advertise here!
xmax on unibox BNK Multi-Way 2 10th November 2008 06:31 PM
Question about xmax mitchyz250f Subwoofers 12 2nd August 2008 08:02 PM
Wrms, FS or xmax onform Subwoofers 4 24th June 2008 07:09 PM
Xmax dallaire Multi-Way 2 25th December 2007 09:47 AM
Determining The XMAX OMNIFEX Multi-Way 11 8th August 2004 06:29 AM
