how connect to subwoofer?
Old 25th November 2004, 05:10 PM   #1
alejo is offline alejo  Argentina
Question how connect to subwoofer?
Hello, I want upgrade my system adding one sobwoofer.
How connect this?
I draw diagram, add the blue circuit is correct?
if not, how obteing signal for sw?
Old 25th November 2004, 10:39 PM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
No one else is answering so...
It is NOT correct if you expect the pot to function as a volume control.
Replace the pot with 2 resistors, about 22K or so, and tie the junction to the - input of an op-amp. The output of the op-amp can go to the filter. After the filter place a volume control.
Old 26th November 2004, 04:11 PM   #3
Ok.
explained of another form: I have a CD, and valve amplifier, and need conect the subwoofer but I do not have output for this.
How obteing a signal sample?
subwoofer IN is only for low level.
thanks
alejo
Old 26th November 2004, 05:26 PM   #4
You don't like my suggestion?
Old 26th November 2004, 05:41 PM   #5
Yes Bill and thank you very much to respond to me !!!,
only want another opinion.
Old 26th November 2004, 09:59 PM   #6
Burnedfingers is offline Burnedfingers  United States
Alejo
Use a 5532 op amp with a regulated +15 and -15 volt supply. Take two 15K resistors to the - input of the op amp and provide your hot signal to these resistors from each channel. A 15K from the noninverting input to ground should work ok. Stick a pot from the inverting input to the output of say 50K or so. This will provide anything from less than unity to way more than unity gain for the buffer stage. This will provide the ability to control your low frequency and sum your signal.
Note* May need to check phase of low frequency output.
Ground the unused portion of your op amp. Some say it causes noise.
Old 27th November 2004, 12:06 AM   #7
Well, there's your second opinion. Same as mine except for the minor difference in resistor values and the location of the pot.
Old 27th November 2004, 12:45 AM   #8
Bill Fitzpatrick
Your values will work fine. The only difference would be the total gain available.
alejo
There you go ...another opinion. Its the easiest and best way.
Old 29th November 2004, 01:06 PM   #9
Thanks Bill Fitzpatrick and burnedfingers for your reply.
Today I´start to work in this proyect.
Alejo
how connect to subwoofer?Hide this!Advertise here!
How connect the Gnd. samsagaz Chip Amps 50 19th May 2008 06:09 AM
How can I connect my subwoofer?? kayjayw Subwoofers 12 26th November 2005 10:33 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 04:19 PM
HELP to connect a subwoofer cristiano Subwoofers 2 16th April 2004 03:14 PM
Best way to connect a sub to a GC? sounder Chip Amps 5 13th October 2003 05:40 AM
Copyright ©1999-2017 diyAudio
