#21 |
130db @ 30hz,you never get this output anywhere but in cars - when it feels very sickening,ive felt it
Double click odd parameters.start at the upper left of the speaker parameters and go to the right. If you look at my website youl see how to use it,an example is digitor horn. |
#22 |
Alright, so I fiddled around with HornResp a bit and used the hypex to play with some different cutoff frequencys. The lowest cutoff it would allow was 11hz. The horn was an amazing 70feet long with a horn mouth area of 10' x 10'. A bit impractical to say the least! I'm starting to change my mind about a basshorn for the Tumult. I think I might try out a TL instead. How insane does a 10hz quarter wave pipe sound? 28feet long
The golden rule of DIY: Build nice, or build twice! |
#23 |
Not competely insane. You could use a sono-tube like the el-pipo. If you cut a 24" sonotube into 4x6'sections you can use sealed boxes to make the corners of the folds. You will end up with something about 8' by 4' square. It could fit nicely standing upright in the corner.
#24 |
Those darned Laws of Physics!
Just do a Tline and be happy with low levels You could always horn down to 30hz with sealed box operation below that |
| tumult | cave | Swap Meet | 0 | 22nd January 2005 10:30 PM |
| What amp for a Tumult? | tvitarelli | Subwoofers | 6 | 30th August 2004 09:31 PM |
| Horn loaded Adire Tumult | eRiCdWoNg | Multi-Way | 6 | 29th June 2004 08:59 PM |
| DIY Sub...1804 vs tumult | xl8ed | Subwoofers | 0 | 31st May 2004 05:31 AM |
| TUMULT arrives | RAW | Multi-Way | 4 | 18th December 2002 01:27 AM |
| Page generated in 0.08614 seconds (71.55% PHP - 28.45% MySQL) with 11 queries |
