Hii All.
a Have in my car 2 Subwoofer from unknow compeny. i have them in my car in ported box. in my last check the "dB geometer" is show a 135.5dB. now i want to change my box to a hornbox to get more SPL........ how much DB the horn box will give me ?! my 2 subwoofers is: 12' 350WRMS 700WMAX 4 OHM my box is the (1) and i want to change to something like (2) but i dont now how to make it in the theory...?? practicably i can do this........ thanks tamir |
#2 |
(1)+(2)
#3 |
Maybe something like the "Wicked One" on Decwares site?
Have a look.. http://www.decware.com/whorn.htm I once planned to build one of these,and had the plans scaled up for a dual 12 inch version,but lost them a while ago.. |
#4 |
#5 |
Banned
You won't get much more with a rear horn because it only loads the rearwave of the driver; there will be additional bass extension, but not much, maybe a dB or two, as a horn that will work to 40 Hz has to be at least seven feet long. With your design that means the box would probably be larger than your car. I built an AutoTuba, which does have a seven foot horn in a box that will fit in a car trunk, you can see it at www.billfitzmaurice.com. It is the most powerful sub you can get small enough for a car.
But even it won't get 135dB, and I don't know of any ported box that is capable of anywhere near that level. How are you measuring this? A typical reflex box will give about 90dB/SPL/1watt/1 meter even with cabin gain, and at 400 watts input that comes to 116dB at 1 meter. You'd need 40,000watts for 136dB. |
#6 |
I'm sure his "db geometer" reading (whatever that is, lol) included the cabin gain of the car with the amp playing at full volume, if not clipping.
#7 |
Banned
I'd guess that's some sort of meter along the Rat Shack lines, and what he reads depends on wherehe puts it. 135dB is easy two inches from the box, ain't never gonna happen a meter away. Or he may be reading total system response, not that of the sub only, making the reading meaningless as far as the sub alone is concerned.
#8 |
yes yes it is device that check your MAXIMOM DB in the front of the car...... so i get a136DB...
i dont now how to say the name of the DB check dvice......sorry. so the horn will be in tune to the front of the car...... i dont how to say it..... but......the space in the trunk is open to the other space in the car. |
#9 | |
| My horn loaded subwoofer. | SkinnyBoy | Subwoofers | 21 | 18th December 2009 04:14 AM |
| horn subwoofer design help | mhtplsh | Subwoofers | 8 | 30th September 2007 10:09 AM |
| horn subwoofer, england | lt cdr data | Swap Meet | 0 | 5th September 2006 11:42 AM |
| Hi , New subwoofer project or horn . | darkm4n | Subwoofers | 5 | 6th July 2004 07:51 PM |
