Hi guys,
I am building some _very_ large permanent installation subs. Does anyone have specs for the EAW L18 851 18" drivers? Thanks, |
#2 |
Banned
I don't have specs off hand, but since EAW is a pro-sound company make well sure before you start that they are appropriate; the average pro-sound sub has an f3 a full octave higher than the average HT sub, irrespective of driver size.
#3 |
Thanks, I'll check into that. I have an email into EAW right now but haven't heard back from them just yet.
#4 |
Banned
Check the RCF website, that's where EAW used to source most of their drivers.
#5 |
fs = 38.7
Qes = 0.38 Qms = 6.00 Qts = 0.35 Vas = 200 liters Re = 5.7 Xmax = 5.1 mm Have Fun!
OMNIFEX |
#6 |
Banned
As I suspected these specs indicate an f3 of 45 Hz, which is quite acceptable for pro-sound, not worth much for HT. At 25 Hz I can blow this puppy away with an eight in a 3.3 cu ft folded horn.
#7 | |
Audio Junkie
Zero
#8 |
Thanks guys.
I'll post a new thread to ask you what you might recommend for my enclosures. I'll post pics of what I have so far too. Later... |
#9 |
Audio Junkie
Just for fun comparison, here are the specs from the Aura sound NRT18-8:
FS: 25Hz Qes: 0.28 Qms = 4.4 Qts = 0.26 Vas = 475 liters Re = 5.6 ohms Xmax = 18 mm That right Kiddies! 18MM Linear max excursion!!!! Now thats a sub!!!! For us in the USA lets put that into perspective, thats 3/4" of one way travel! Zero
#10 |
Why would anyone try to reproduce 25Hz with the RCF?
You want a sub, you use a McCauley 6174 (fs = 15Hz)
OMNIFEX |
| how to understand driver specs? | gasstronamicle | Multi-Way | 4 | 12th November 2007 07:48 AM |
| Alps RK40 pot aka "black beauty" specs? | h_a | Parts | 2 | 28th January 2007 07:48 AM |
| help with driver specs | threegee | Subwoofers | 19 | 24th April 2006 05:39 AM |
| Focal driver specs??? | BigSmooth | Multi-Way | 0 | 23rd July 2005 08:26 AM |
| Any specs on this JBL driver? | Bull | Car Audio | 4 | 19th September 2003 08:21 PM |
