Old 8th October 2004, 08:07 AM   #1
m4dm4n is offline m4dm4n  Sweden
Default 6th bandpass with slave.?
in room respons
The yellow is 2st w8-740c in sealed, purple 1st w8-740c 6th order bandpass and grey is 1st w8-740 in vented. The sealed box will bottom out at 30hz.
Is it possible to do this design with 6th order and use a slave to tune the rear chamber ?
The groupdelay is just a bit higher at 50-150hz, but will this mess up the result ?
Old 13th October 2004, 01:43 AM   #2
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
Interesting response curve on the sealed and vented enclosures, I am curious why there is such a rolloff above 100hz. The sealed enclosure also seems to be amazingly flat down to even 15hz. I'd imagine you have the an EQ/Filter on winISD enabled? Im having trouble on what you mean by tuning the rear chamber with a slave? I've never heard that term before. Please explain
The golden rule of DIY:
Build nice, or build twice!
Old 13th October 2004, 08:53 AM   #3
In Winisd you can use filters and EQ, yes =)
the rolloff above 100hz is a LP butterworth at 80hz. Because aditionall filters give a higher groupdelay so i just wanna see how much worse it get's.
Yes the sealed got a response down to 15hz, but that´s in a room measuring 4.3m x 4m. In winisd you can add roomgain by adding a linkwitz transformer and use this values =
F0 = 345 / (largest distance in room *2) ex. 345 / 4.3 x 2 = 40.11hz
Fp = 15
Q0 = 0.707
Qp = 0.707
tuning the chamber that have a 23.48hz,, That's almost impossible to do in a 14.4liter box,, But if you use a slave it's possible.
As mentioned above, the sealed got 2 element, and the vented and bandpass got only 1 element. (Tangband W8-740c)
Old 14th October 2004, 10:52 PM   #4
BassAwdyO's Avatar
I'd assume you mean Passive Radiator by slave? Sorry I've never heard the term slave before. If you do mean Passive radiator I would say, SURE you could definately tune the rear chamber with it instead of a port! It will give you a slight response difference due to the notch in Frequency response at PR resonance. It will also give you a difference in group delay (another dip at PR resonance). It really shouldnt be an audible difference versus using a port, except no port turbulence! PR's are alot more expensive than ports, but they have their advantages. I personally dislike bandpass enclosures. I'd much rather use a sealed, vented, PR, or TL. Vented and PR will give you the best low frequency extension (without going crazy on Xmax). You'll need a Low pass filter with a bandpass design despite the 12db/octave rolloff on the high end. Once you get above the F3 on the high end the port basically doesnt exist to the driver so the driver acts as if its in a bandpass enclosure without ports. this causes extreme panel vibration (a very bad thing)
Old 18th October 2004, 08:19 PM   #5
Default how many G does Passive Radiator do ?
yes PR =)
Called "slav" in swedish, slave in english.
I've tested with a PR now and i don't know if i like the build. You can't hear if the speaker is in "damage" area
typical bandpass ^ . I'll stick to sealed and PR design from now.
? ? How many G does the PR accelerate ? ?
I've heard 60 G for speaker cone, but the PR should not accelerate that fast i believe.
6KN6-PP-guitar slave davorin Tubes / Valves 17 27th April 2011 06:51 PM
Slave Transport to DAC-AH regal Digital Source 7 7th August 2006 07:33 AM
Studer 727 slave to DAC ? Bernhard Digital Source 0 28th July 2006 07:48 AM
Slave SqueezeBox to DAC? ezkcdude Digital Source 1 1st March 2006 03:02 PM
DAC in Master, CD in Slave mode - How? spavleski Digital Source 12 13th August 2005 02:11 PM
Page generated in 0.08846 seconds (77.27% PHP - 22.73% MySQL) with 10 queries
