I am planning on building a sub using a shivas sub driver in the 88.5 ltr sealed box .
my plate amp has a bass boost circuit of 6db @ 35 hz . is this going to cause me any problems . Is there a way to disable it or lower it . the plate amp is from jaycar http://www1.jaycar.com.au/productResults.asp?FORM=CAT the same as these . but different amount of output |
#2 |
with winisd PRO + update you can see the resultant response with EQ
Depending on what the response is,and what you like,it may or may not give you what you want. Yes there is a way to disable it. search in yahoo for 'critical q subwoofer' |
#3 |
What is the Q of the eq on the jaycar amp??
#4 |
I have no idea what the Q is . sorry
also how do i allow for the 6db boost in winisd pro ?? |
#5 |
I am not sure but if you are using a shiva (I am using a tempest, already have it, just finished the box) you can use lspcad which is a bit more comprehensive. After re-creating your alignment in lsp cad go to the "box/filter/eq" menu and go to equaliser, you will get the predicted effects of the equaliser.
I am guessing you know what the frequency and boost amount is (35hz and 6db), You could say that the Q is the "width" of the boost with the lower the number the wider the area that it affects. For the jaycar amp i would stick it at around 1 for an estimate. |
#6 |
Its sallenkey EQ as far as i know,the Q isnt adjustable.
Only the Frequency and magnitude. LSP cad isnt free? WIth signal generator and oscilloscope you could measure it and plot :-) also how do i allow for the 6db boost in winisd pro ?? If you downloaded the PATCH also,on the driver box,theres an EQ tab. http://members.ozemail.com.au/~joera..._technical.htm Note that -12db at 10hz is slightly helpful for preventing ported overexcursion(but maynot be enough at extreme power levels) |
#7 |
#8 |
according to adire audio . I should not use this plate amp on a shivas .
didn't say why. have asked why |
| Bass Boost Circuit | metal | Chip Amps | 0 | 15th November 2005 08:29 PM |
| bass boost | odysseybmx414 | Chip Amps | 3 | 26th August 2005 09:05 AM |
| Dipole bass with Adire Shivas? | mazeroth | Subwoofers | 8 | 14th August 2005 10:56 AM |
| How much bass from four sealed Shivas? | mazeroth | Subwoofers | 6 | 4th August 2005 01:44 PM |
| simple bass boost circuit | deepanger | Solid State | 11 | 28th December 2002 01:37 PM |
| Page generated in 0.09570 seconds (79.26% PHP - 20.74% MySQL) with 10 queries |
