Old 20th July 2004, 11:54 PM   #11
If you do set things on it, a painted surface will scratch fairly easily. The truck bed liner method is only a light coating so I would not see it adding much to the durability. Atleast with the application I did.
Old 21st July 2004, 01:01 AM   #12
Jimmy154's Avatar
Truck bed liner is used for the exact purpose of adding durablity and preventing scratches on truck beds, no? Your coat might be too thin you say, then maybe a thicker coat would be needed for wrenchone's application? I'm mentioning this not to be a smart a**, as I usually do , but after hearing this I'm going to try this finish.
Your speakers look very nice BTW. Not just the finish either, that Elf Spire design looks very nice.
Old 21st July 2004, 01:37 AM   #13
the PE vinyl is very tough stuff - 10 mil. I don't think you'll be disappointed.
Old 21st July 2004, 01:49 AM   #14
Yeah, I went for the cheap spray on finish too.
Looks similar to m1abrams finish.
I sprayed on a couple of coats of flat black paint first, then used the truck liner.
Old 21st July 2004, 03:47 AM   #15
M1, those look FANTASTIC! I think the spray-on is the way to go. Actually, I'm positive
Old 21st July 2004, 11:59 AM   #16
Oh if you do a thick coat of the truck bed liner stuff it will be strong as all hell. But I found the thick coats will give you a glossy finish. Which is not what I was looking for.
I like the finish but it may not be as durable as you may need. Experiment with it is the best way to go. Its cheap enough to grab a scrap piece of wood to try different things on.
Old 21st July 2004, 12:37 PM   #17
http://www.elesgoflex.com/elesframe.html
Has anyone of you heard about this new flexible laminate?
Well, it is expensive (in Germany about 40 € a roll (1 x 2,5 m), but I had the chance to look at a few speakers with this finish, and it is amazing...
Try and have a look on the "Antique beech" or "Yew" designs...
I think about using it by myself with my next projekt (Visaton Atlantis).
Greetings, B.
JayBeeOnline.de
Old 22nd July 2004, 03:41 AM   #18
Another question. When attaching the sub to the box what do you use to seal the subwoofer and the box together so there's not air leakage? Maybe some strip caulk?
Old 24th July 2004, 07:28 PM   #19
Any ideas on the seal?
Thanks.
Old 26th July 2004, 02:47 PM   #20
Solinar is offline Solinar  United States
http://www.partsexpress.com/pe/showd...number=260-540
Cheap Subwoofer build for less than £150 llyrroberts Subwoofers 10 26th January 2009 10:35 AM
cheap subwoofer cable? gychang Subwoofers 6 1st February 2007 03:42 PM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
cheap subwoofer cabinets cowanrg Subwoofers 0 7th July 2006 03:56 PM
My throw-together cheap subwoofer nobody special Subwoofers 25 5th February 2003 05:19 PM
Page generated in 0.11564 seconds (80.04% PHP - 19.96% MySQL) with 11 queries
