sub hookup questions
Old 9th July 2004, 07:17 PM   #1
wharfrat is offline wharfrat  United States
Default sub hookup questions
I have just finished rebuilding a subwoofer, and I am trying to integrate it into a music/home theater system (Denon 3805 av receiver). Originally, the sub was a sealed 12" powered by a bridged Hafler 220 (350 watts into 8 ohms, I don't know how many into 4 ohms). I used an old jbl active crossover/summing device that used two channels of input and three channels output (left, right and a summed low freq. channel). I Can't figure out how to use the crossover with the LFE output of the av receiver. Currently, I am using a dual voice coil Shiva. I have unbridged the Hafler and power each voice coil with a seperate channel, mainly because the Hafler manual states that it is prone to overheating if driving less than 6 ohms in bridged mode. I have simply paralleled the LFE output into the amp, using the receiver's crossover, but this gives me less flexibility in setting the crossover frequency and I lose the seperate gain adjustment of the active crossover. Can the active crossover be integrated into the system? I suppose I would have to split the LFE output into two channels, which would go into the active crossover, which would then output one summed channel, which would also have to be split into two channels to go to the amplifier. Will that work? If so, how should I set the av receiver's crossover so that it will integrate well with the active crossover? Any advice on how to make this work will be greatly appreciated.
Larry M
Old 9th July 2004, 07:44 PM   #2
BillFitzmaurice is offline BillFitzmaurice  United States
Banned
You don't have to use all the crossovers outputs or inputs. Run the LFE output of the receiver to one input and its summed output to the sub amp.
Old 10th July 2004, 01:35 AM   #3
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Why not just use a splitter cable to split the mono sub signal coming out of the receiver and plug that into the left and right input on the amp amp you are using for the sub?
Everyone has a photographic memory. It's just that most are out of film.
Old 10th July 2004, 06:27 PM   #4
JohninCR - well, that's what I'm doing now. The problem is I then lose the variable gain feature, the variable crossover frequency and perhaps the steeper rolloff of the active crossover. It may be that it's not worth trying to integrate the active crossover, though I would at least like to be able to control the gain of the sub amp.
Larry M
Old 10th July 2004, 10:39 PM   #5
I believe that Denon has variable gain and variable xover for the sub right from the remote control. I know my Denon 1804 does and I change the settings occasionally, but I haven't changed the sub amp settings since I first set it up.
Old 11th July 2004, 04:06 AM   #6
chrish is offline chrish  Australia
chrish's Avatar
Wharfrat, if I understand you correctly, you wish to use your current active crossover in your system to get left, right, sub/LFE? I think you will get what you want by telling your AV receiver that you have no sub/LFE and setting your speakers to large. What this should do is direct all of the low freqs to the left/right outputs and nothing to the sub output. You can then use your active crossover sub/LFE output to drive your sub.
Chris
Old 11th July 2004, 09:12 PM   #7
Thanks, good idea, I'll try that.
Larry M
sub hookup questionsHide this!Advertise here!
crossover amp hookup jonesk1978 Car Audio 2 26th February 2009 11:40 AM
Hookup wire Buzzy Solid State 6 4th July 2008 01:39 AM
behringer dcx HOOKUP IMSTOOPID Digital Line Level 8 5th February 2008 06:21 PM
Hookup Wire Q matthewm Chip Amps 3 22nd November 2006 04:06 PM
