#21 |
If you can afford it,i guess you should buy enough amplifier power to reach xmax.Problem is,the cost and shipping.Consider www.aussieamplifiers.com
This should be easy with a low tune and HT 23mm oneway? thats abit more than a shiva,which is notoriously easy to bottom with EBS alignment and a few hundred watts. Cheers |
#22 |
UPDATE: I bought the Behringer EP2500
While it retails for AU $800 I got it for $630 at Factory Sound, who Behringer Australia described as "a big discounter" ie they offer good prices. I found this to be true as another store offered it for $700 and when I tried to push for a better price from a local place, they guy was struggling to offer it for $695! I did get hold of an Alesis Matica 2nd hand amp to try out, but wasn't totally satisfied. Even with 450w per side it was clipping when I still wanted to crank it some more. Also noisy fans. I sent it back to the guy who was selling it. Then I had a look at QSC USA 900 with the same power and a quieter fan, which I returned as I thought it was not working, until later I found out I had a cable loose (v embarrasing!) ... it would have cost me $650 had I not returned itI like the Behringer more than the others, it has yet to run out of steam or even clip at all. While I was tempted to get the cheap Biema amp which was going for $450 and had 450w (although I think its more like 400), via trying things out I have concluded: * not enough power * headroom is very valuable * peace of mind is worth something - saves you a lot of worry if you like to crank, you don't have to watch the clipping indicators all the time * not worth buying an amp that can't be serviced (Biema don't supply sufficient info for anyone to repair them, so once they fail, you have to buy a new one) - lesson: don't buy throw away amps, they are more likely to fail anyway Now to get rid of the fan noise .........
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#23 |
hello paulspencer!
how are you? I would send it for you almost free, basicaly I payed $50 per unit, but have not idea about delivery method.
Artmaster live in www.artmaydan.org.ua |
#24 |
This is an amp schematic I presume?
#25 |
it is
I've use it in my sub and I'm sure - this is the best of the world. I'm buy it from author directly. and I'll be able to buy it for you, if it's necessary
#26 |
I'm fine thanks Yuri, I've just bought an amp!!!
#27 |
it's ok
good luck and HNY!
#28 |
I found nice cases for amp's. cool design
http://www.casemall.net/case/case-htpc.htm I'll ordering it after NY holiday
| My new subs. | Phil Olson | Subwoofers | 5 | 26th April 2008 07:00 PM |
| Looking at more subs. | skooter | Car Audio | 3 | 2nd December 2007 07:10 PM |
| SUBs with these:? let us know... | kyselym | Subwoofers | 0 | 11th January 2007 06:33 PM |
| Convert floor standers to subs with Tang Band 8" subs? | prerunnerv6 | Subwoofers | 3 | 26th February 2006 01:44 AM |
| 2 subs one box/2 subs 2 boxes | vetkilr | Subwoofers | 5 | 22nd February 2006 10:27 PM |
| Page generated in 0.12288 seconds (61.17% PHP - 38.83% MySQL) with 10 queries |
