Well i have posted here a few times about deciding what sort of sub to build but i have now made a decision. I am going to build a sonotube as i like the look of them and i feel that it will be easy. One question on my mind is how the hell do i work out the sizes i am going to need if i use a Dayton 12" DVD Subwoofer and is there any way of knowing what sort of bass i am going to get. Have i chosen a bad driver if yes can you reccomend another driver to use? I dont really want the sonotube to be huge as it has to fit in my bedroom and is there any software like winisd that will let me calculate the sizes needed when making a sonotube. Greg. |
#2 |
If you are building a standard sealed or vented sub, just make the appropriate volume calculations...it is no different than building a sub in a square box.
If you want to build a TL that is a little more complex but you'll still need to follow a standard recipe or do a lot of math. |
#3 |
So ur saying that i could tap the drivers specs in to winisd and constuct a vented box with the program and then make a sonotube out of the sizes given
Greg. |
#4 | |
Using winisd to model a vented box will yield an optimum enclosure volume. Then just whittle down your sonotube so that the internal volume matches that given by winisd. In other words - "size (i.e. *volume*) does matter, shape does not" (wish this was true in all other matters).... Cheers, Bill |
#5 |
How do i know what volume my sonotube is, how do i work it out and do u reccomend another driver?
#6 | |
Check out this URL: http://www.quux.net/roo/diy/sonosub/sonocalc_old.html Once you have the needed volume (from winisd) you can plug in the numbers and voila.......... Hope that helps, Bill |
#7 |
Find out what the volume you need is in WinISD and then go here.
http://www.quux.net/roo/diy/sonosub/tubecalc.html |
#8 | |
But Mikey's link is easier to use. |
#9 |
Well i would first like to say thank you for the help and information i have recieved and i have now decided that i am going to use a 12" Adire Audio Shiva in a 128 litre vented sonotube. The graphs in winisd show that it will go down to at least 20hz so i am happy with that
One last thing i wish to ask before i hit the garage is what sort of finish can u use on a sonotube. Thanks For all the help. Greg. P.S I will post back with the pics and listening thoughts when i have constucted the beast. |
#10 |
Sonotube can be painted, wrapped in fabric or carpet, veneered, alomost anything can be done to it without any problem.
If it sounds good... it is good! |
| Sonotube in the UK ? | matt09 | Subwoofers | 8 | 14th March 2007 09:38 PM |
| Sonotube Project | CARTRulz | Subwoofers | 40 | 6th July 2006 11:37 AM |
| where to buy sonotube? | trespasser_guy | Multi-Way | 7 | 12th May 2003 11:07 PM |
| Where can I get sonotube? | AJ Bertelson | Multi-Way | 8 | 24th February 2003 01:57 AM |
| Sonotube | xr628 | Subwoofers | 6 | 20th February 2002 08:57 AM |
| Page generated in 0.09952 seconds (78.72% PHP - 21.28% MySQL) with 10 queries |
