Recommendations for subwoofer
Old 22nd May 2004, 09:38 PM   #1
greg_mcquaid is offline greg_mcquaid  United Kingdom
Default Recommendations for subwoofer
Hi all,
I wondered if any one could suggest a driver to use for making a subwoofer to plug into my sharp mini hifi. It has to be realitivly cheap and i will model it in WinISD. I was thinking of using an 8" driver in a vented enclouser or maybye 2 8" Dayton DVC's in isobarik in 4th order bandpass configuration. Any help apreciated
Greg.
Old 22nd May 2004, 09:48 PM   #2
coolkhoa is offline coolkhoa  United States
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
Also check out Peerless' 8" offerings.
KTK. Kool To the Kore.
Old 22nd May 2004, 09:54 PM   #3
Default Peerless 8"
What would be the best box foe thi driver. Has any one used this driver? What is it like?
Greg
Old 22nd May 2004, 09:58 PM   #4
sam9 is offline sam9  United States
sam9's Avatar
Look at the PartsExpress Titanic series.
Old 22nd May 2004, 10:11 PM   #5
Default Dayton 8" DVC
This is a pair of 8" dayton DVC subwoofers in isobarik configuartion.
What do u think of these graphs? And would this be a good idea to use this with my hifi?
Greg
Old 22nd May 2004, 11:51 PM   #6
coolkhoa's Avatar
Default Re: Peerless 8"
Greg
Which one are you talking about?
Old 23rd May 2004, 04:41 AM   #7
jjdche is offline jjdche  United States
How 'mini' is this mini-hifi? You're only getting to about 80Hz on the high side of the bandpass, so you're system will need solid extension down to 80Hz.
Bandpass boxes are notoriously tough to tune as well. Its highly unlikely that you will get good results if you build exactly what the modeling program tells you.
Old 23rd May 2004, 05:01 AM   #8
jonz is offline jonz  Canada
What are you powering it with...a separate amp I presume?
Old 23rd May 2004, 07:08 AM   #9
I will be powering it with a sperate amp. I was looking at the maual for the mini hifi and it says the the subwoofer output is it at 70hz no i dont know if this will be enough for low bass.
Greg
Old 23rd May 2004, 07:21 AM   #10
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
Greg
Well if cheaps your game, then I suggest a Sonotube. Go to home depot look in the concrete/roof section by the lumber (usually), and look for these cardboard cylinders. They usually have 8" and 12". Buy the 12" one (usually ~$8), and then go and find the "smaller" sheets of plywood/mdf (usually 2'x4' sheets), and sometimes they have 12" MDF circles for like $5.
Anyways the whole point here is that you can pretty much piece these all together, and have a cheap effective sub. And don't freak out that the cardboard looks thin. If you brace it...especially a MDF ring in the middle...it is very very sturdy, as a cylinder spreads the stress over the entire circle. You will be amazed!
Recommendations for subwooferHide this!Advertise here!
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
Need some subwoofer recommendations. jaimegmr Subwoofers 12 11th July 2005 08:48 AM
diy subwoofer recommendations? jaybird Subwoofers 20 7th December 2004 08:21 PM
Subwoofer recommendations for Sonab OA14s Mcraiga Subwoofers 0 15th April 2004 04:51 AM
Sealed Box Subwoofer Recommendations Javaman Subwoofers 12 21st December 2001 01:25 AM
