I need help with subwoofer deisign: HUGE inexpensive subwoofer
Old 4th May 2004, 12:12 AM   #11
hottyson is offline hottyson  United States
hottyson's Avatar
Thanks everyone for the quick and helpful reply's.
Originally posted by johninCR
You've got enough room for dipole. Use lots of cheap drivers with small magnets. I've used some cheap nippon 12"ers to good effect. Bring some cardboard and a knife to audition them, to find the ones that get the best bass on OB in the $5-$15 range. You want to listen to the ones with the smaller magnets which indicates higher Qts.
This sounds very good. Are you sure that I can get away with a dipole design? I only have sixteen inches from the wall to the screen. I could build the bafle right up to the screen. Would the sixteen inches behind it work?
I can fit quite a few drivers on a baffle of 3ft by 9ft. They will all be fed a mono 300 watt + subwoofer amp (a bridged Kenwood amp). Total impedance should be 8 ohms after proper wiring. If this will work can anyone suggest good drivers to use?
(links too if you have one)
Old 4th May 2004, 12:17 AM   #12
hottyson's Avatar
Originally posted by Dave Jones
This one has a Qts of .65 in a 1000 L box:
http://www.partsexpress.com/pe/showd...number=295-450
... and it costs 85 bucks. Nominal F3 would be about 30Hz. That's some way deep bass. Someone who knows something about this stuff would have to say whether that would be too boomy in the particular room the setup is going into.
Wow! Way cool find. Thanks!
My garage is right behind my home theater and I could easily mount four of these to the wall with some work. Do you guys think that four of these mounted directly to my wall might be a better approach than going with dipole design?
Old 4th May 2004, 02:23 AM   #13
454Casull is offline 454Casull  Canada
With that much space you might as well go for a 20Hz horn...
Old 4th May 2004, 02:40 AM   #14
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
That's absolutely right. A good bass horn could be the cheapest option driver wise and get huge output if well executed.
Everyone has a photographic memory. It's just that most are out of film.
Old 4th May 2004, 03:41 AM   #15
jelou is offline jelou  Belarus
Any information about diy egglestonworks IVY speaker?
Any photo reference?
Old 4th May 2004, 03:43 AM   #16
bzdang is offline bzdang  Canada
bzdang's Avatar
How about a pair of labhorns built into the unit ?
I listened to one at Yorkville Sound and it made my pantlegs flap.
Build the Horns!
I just have to figure out how to hide a pair of them where my wife won't find them. My workshop is under the livingroom....
http://www.prosoundweb.com/community/forum.php?board=3
http://www.partsexpress.com/pe/pshow...70&ctab=2#Tabs
When all else fails, men turn to horns. - bzdang
Benford's law of controversy - Passion is inversely proportional to the amount of real information available.
Old 4th May 2004, 03:51 AM   #17
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
I'd say 4 of the regular daytons, their $27 each when you buy 4. Their pretty good quality in my opinion, their pretty heavy and solid for the price. Plus with four you'd be looking at like 96db sensitivity and 8 ohms, add a modest plate amp and your set for $250 excluding wood.
I need help with subwoofer deisign: HUGE inexpensive subwooferHide this!Advertise here!
Small inexpensive subwoofer amp imperfectcircle Chip Amps 1 8th January 2007 10:15 PM
Possibilities for inexpensive subwoofer amplifier kits? Spasticteapot Subwoofers 4 20th November 2006 10:59 PM
subwoofer project, which subwoofer? Davlaf Subwoofers 12 9th November 2006 03:59 AM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
Copyright ©1999-2017 diyAudio
