How About These for Dipole Sub?
Old 2nd May 2004, 12:43 AM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Beat to the punch by Milo :^)
This driver has such a large Vas, that either an open baffle or the next room as box are all that is practical.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd May 2004, 02:02 AM   #12
454Casull is offline 454Casull  Canada
Its displacement is about 1.15L, which limits you to a maximum of roughly 86dB at 25Hz at 1 meter (taken from Linkwitz's OB spreadsheet).
EDIT - given a 500mm path difference
Old 2nd May 2004, 03:50 AM   #13
frugal-phile(tm)
planet10's Avatar
is this the wrap-around distance between front & back?
If it is, the FW800 would have a minimum of 800 mm being an 800mm driver... larger would be more likely.
dave
Old 2nd May 2004, 05:29 AM   #14
You know, I really have no idea.
Old 2nd May 2004, 05:32 AM   #15
My dear apologies! That's not the maximum SPL, that's the sensitivity!
86db@1W@25Hz isn't too bad... But you can't get much louder than that at listening position, I would think.
Old 2nd May 2004, 06:54 AM   #16
GM is offline GM  United States
GM's Avatar
Ignoring any baffle/room gain, it calcs to ~91.63dB/m/18Hz, 103.68dB/m/36Hz, 115.72dB/m/72Hz at Xmax, so not too shabby once the room is factored in. Still, you can buy a lot more Xmax and the power amps to drive them for $2446.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd May 2004, 06:13 PM   #17
A3rd.Zero is offline A3rd.Zero  United States
A3rd.Zero's Avatar
Now GM, that's not the point. I want a subwoofer that I can sleep in!!!!!!! The bigger the better!
How did I live without Nina Simone for so long?
Old 3rd May 2004, 02:22 PM   #18
Roscoe Primrose is offline Roscoe Primrose  United States
I'm running two pairs of the Dayton 15" IBs in W-frames, and am quite happy with the performance...
Peace
How About These for Dipole Sub?Hide this!Advertise here!
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 8 29th March 2015 09:45 AM
dipole or not? maghen Multi-Way 21 26th May 2008 12:38 PM
(WW) MMTMM dipole 4 vs 3 way / dipole benefit frequencies? charliemouse Multi-Way 25 8th July 2007 12:19 AM
Dipole Sub in car?can I? mikee55 Subwoofers 9 2nd January 2006 05:06 PM
When is a dipole not a dipole anymore? Bas Horneman Multi-Way 5 5th December 2003 04:02 PM
Copyright ©1999-2017 diyAudio
