sub series / parallel Qts parameter - diyAudio
Old 30th April 2004, 09:08 PM   #1
diyAudio Member RIP
Default sub series / parallel Qts parameter
Given a dual voice driver has fixed Vas and Fs parameters,
I assume there is a simple relationship between Qts for
series and parallel connection but I don't know what is is.
Assuming Qms is high so Qts ~ = Qe whats the relationship ?
sreten.
Old 1st May 2004, 12:22 AM   #2
Svante is offline Svante  Sweden
Svante's Avatar
I think the key is in BL and Re.
B is always constant.
Qes=w0*Mms/((BL)^2/Re)=w0*Mms * Re/(BL)^2
Compared to single coil:
Series connection:
L is doubled, so BL is doubled. Re is doubled.
So Qes is halved
Parallel connection:
L and BL is the same*. Re is halved
So Qes is halved
This should mean that both Qes and Qts are the same for the dual coil driver regardless of series or parallel connection.
This also makes sense in that 4 and 8 ohm versions of drivers usually have the same Qts, even though the number of windings has been changed.
*See the two windings as running close to each other in parallel. This would mean that the voltage at any given point along the wire would be the same in both wires. So we can join them together in one thicker wire without changing the behaviour. Alternatively the length can be seen as doubled and the current as halved. A halved current is equivalent to a halved B, so BL is the same.
This is just taken from the back of my head at 01:20 at night, so I might have got it wrong. I have a faint memory of that I saw this explained on some site describing the Shiva driver, that could be good to look up too.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 1st May 2004, 12:29 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Imagine how Re and BL change.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 1st May 2004, 06:46 AM   #4
f4ier is offline f4ier  Australia
f4ier's Avatar
le'me know what you think of this one
Crossover/Subwoofer Simulator
Old 1st May 2004, 09:41 AM   #5
Svante's Avatar
f4ier:
Hmm. If Qes is the same in the two configs, at Qms also is, mustn't Qts be the same too? (two first images)
Old 1st May 2004, 02:14 PM   #6
Ron E's Avatar
Isaac,
I think in the configuration with one amplifier connected to each coil, with separate signals, you need to use the same parameters as when one coil is shorted (with a resistor equal to the output impedance of the amp). If both channels play the exact same signal, it would be the same as parallel connected case driven by one amplifier, but the impedance to each amp is double...
Old 3rd May 2004, 12:50 PM   #7
f4ier's Avatar
Svante, yep, Qts for both configurations is the same, I included the equation for Qts in the first set of parameters just for convenience (so that the reader doesn't have to scan the text to find the Qts equation).
Ron, section 1f is consistent with your point, but I failed to make it just as specific. I'll clarify 1f and its corresponding column in the table as soon as possible, that page needs to be updated anyway. Thanks for point that out.
What would you do? series/parallel MtnBob Multi-Way 22 23rd August 2016 02:41 AM
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 20th February 2014 12:16 AM
series or parallel? medicman Tubes / Valves 5 22nd January 2009 05:42 PM
Series vs parallel? legendaryfrog Full Range 5 14th December 2006 03:50 PM
series vs parallel SPL? 2litre Multi-Way 16 22nd February 2006 10:58 AM
Copyright 1999-2017 diyAudio
