Converting a Passive Subwoofer to Active
Old 28th April 2004, 08:47 PM   #1
noromamai is offline noromamai  Netherlands
Default Converting a Passive Subwoofer to Active
I've searched the net for information but haven't been able to find any (perhaps i am using the wrong keywords). I've tried using a 40Watt power amplifier (http://www.kemo-electronic.com/en/module/m034/index.htm) to no avail, nothing seems to be happening. If anyone can tell how I can make this all happen, I'd appreciate it.
Old 28th April 2004, 10:49 PM   #2
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
You need to provide more details...what is your passive sub, what does it look like, how is it wired up, etc.
How did you wire the 40W amp up? If you got absolutely no sound of any kind from the sub, then the amp could not possibly have been wired up properly unless the amp is defective.
EDIT: I noticed that the amp does not specify where to ground the input signal, and it only has 500mV sensitivity, so how you wired it up is even more important.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 30th April 2004, 09:09 AM   #3
R.I.P.
The module appears to be suitable for in-car use.
I suspect you are doing something fundamentally wrong.
sreten.
Old 30th April 2004, 03:37 PM   #4
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
I notice that the photo of the unit in the pdf data sheet linkable from the web site and the photo of the unit on the web site itself are different in that the + and - power inputs are swaped in position. The question arises as to where to connect the signal ground.
Old 15th April 2007, 05:49 PM   #5
fasterstill is offline fasterstill  United Kingdom
Default did this get sorted?
Have the same problem with this unit, did it get sorted?
Old 16th April 2007, 07:29 AM   #6
R.I.P.
- is ground, + is =ve voltage, in = input voltage.
The output must be bridged, so neither should be earthed.
/sreten.
Converting a Passive Subwoofer to ActiveHide this!Advertise here!
Converting Active monitors to passive. Help! Stereomaster Multi-Way 21 10th May 2009 07:17 PM
subwoofer crossover passive and active yikchean Subwoofers 3 3rd December 2006 02:18 PM
converting table to subwoofer abrunger Subwoofers 15 14th October 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Converting passive x-over into active x-over Franklin Multi-Way 16 27th October 2002 12:08 PM
