Removing air leaks around the woofer
Old 21st April 2004, 05:45 PM   #1
Wingfeather is offline Wingfeather  United States
Default Removing air leaks around the woofer
I've put my Titanic 15" mkIII sub system together in a stuffed 65l box (made from 18mm MDF, double-thick on the front and back panels). PE supplied a roll of caulk (that stuff really isn't very nice to work with, btw) to seal the mounting flange onto the front of the box. However, I can't eliminate a few air leaks, and it's annoying me. I've removed the driver to check that there are no gaps in the caulk, and *very* firmly reattached it. No luck.
What do I do?
Thanks!
Wingfeather
Old 21st April 2004, 06:05 PM   #2
On Hiatus
SY's Avatar
Softer caulk
Silicone sealant
Foam weather-stripping
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st April 2004, 07:59 PM   #3
jonz is offline jonz  Canada
Get the quality "close cell" weather stripping...get the one thats 1/4 by 1/2 .......nothing goes through that..
Old 21st April 2004, 08:03 PM   #4
Magura is offline Magura  Denmark
Magura's Avatar
At Dynaudio they use something like neoprene foam, it sets well and lasts forever.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Removing air leaks around the wooferHide this!Advertise here!
Removing woofer from an Alesis Monitor One ReidK Multi-Way 4 1st March 2007 04:22 PM
Air leaks in horns xcortes Multi-Way 6 20th August 2004 05:48 PM
Arrggg Leaks!!! RyanC Multi-Way 10 6th June 2004 01:42 AM
How do you check for leaks? viper073 Multi-Way 21 14th January 2003 03:13 AM
Copyright ©1999-2017 diyAudio
