best woofer for tham12, i tried with rcf midbass..
Old 20th July 2018, 08:56 PM   #11
Djim is offline Djim  Netherlands
If you add the load resistance (based on Zmin) your Xmax will be reached with 317 Watts @ 49,62Hz (Zmin = 7,0734 Ohm) That means an amp rating of 280 watts @ 8 Ohm...
Old 20th July 2018, 09:26 PM   #12
angelodj is offline angelodj
while the original cone the 12ps100 can go beyond as power?
I'm worried because I'm building 8 cabinet tham 15 (mk2), to be used with 15nbx100 that I have already ordered, I would not want to use the power due to too much compression that makes me go to limit the xmax.
But there is a user of this forum that says to use the tham 15 with the 15ps100 with 1250watt .. hopefully good!
Old 20th July 2018, 09:33 PM   #13
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Stop using the maximum SPL tool. In theory the 500W amplifier is powerful enough to drive the speaker to X-max, and the speaker will not stop when it reaches x-max.
In practice the speaker could probably use a bigger amplifier.
More importantly the high pass filter needs to be set to stop over excursion at lower frequencies. Run the sim for acoustical power and use the filter wizard to look at the displacement. My guess is as I said before 4th order hi -pass at 40Hz
Old 20th July 2018, 10:03 PM   #14
Thanks for the info!
in fact on the 12th, I put a 45hz filter! I thought about 15 "to filter at 35 / 40hz
best woofer for tham12, i tried with rcf midbass..Hide this!Advertise here!
Usher S-520 woofer/midbass problems? treuben Multi-Way 0 11th February 2017 05:19 PM
compromise = small woofer - larger (horn) midbass - what woofer types blend well? freddi Multi-Way 1 31st October 2015 12:15 PM
Just looking for the perfect 5.5" midbass / woofer hukkfinn Multi-Way 24 17th July 2012 02:17 AM
Which midbass woofer for TL? CharlieM Subwoofers 7 17th November 2010 08:10 PM
Sweet little $15 Woofer/Midbass discreteouts Multi-Way 21 30th March 2008 12:24 AM
