tham15 vs standard horn (80 - 40hz)
Old 9th July 2018, 09:55 AM   #1
angelodj is offline angelodj
Default tham15 vs standard horn (80 - 40hz)
Hello everyone, let's imagine the usual disco system:
for a scalable system, which of these bass solutions behave better in frequencies ranging from 80 to 45 / 40hz?
suppose we use one or two 3-way horn heads per side, 80Hz cut
with the same amount of space
from 2 to 4 bass like those in the picture (ts118 or f118)
from 4 to 8 bass tapped horn type tham 12
or 2 or 4 (but also 6 saw the small footprint) tapped horn 15 as tham 15
turbosound spl:
what solution will the predestined work do better?
edit: the boxes in photos do not reach 80hz but imagine a system with res3 or tms4
tham15 vs standard horn (80 - 40hz)Hide this!Advertise here!
THAM15 - a compact 15" tapped horn martinsson Subwoofers 448 17th July 2018 04:52 AM
horn-loading standard dome tweeters thadman Multi-Way 12 19th December 2006 07:51 AM
searching for a 40hz-300hz bass horn patriz Multi-Way 8 1st November 2003 09:16 AM
40hz horn modeled mikee12345 Multi-Way 0 30th September 2003 05:45 AM
Resources saved on this page: MySQL 68.42% / PHP 27.83%
