real efficiency tham 15 martinsson
Old 9th July 2018, 02:21 PM   #11
chris661 is offline chris661  United Kingdom
chris661's Avatar
Originally Posted by angelodj View Post
which tapped horn do you recommend that be as efficient, as compact as possible?
jbell ss15? or 18" version (Xoc1 ) tham18?
will have more efficiency in the 40-80hz band 6tham15 or 4 tham 18?
Small, efficient, low bass - pick any two.
Hoffman's iron law.
I usually pick a low-frequency cutoff and then play around with the other two, favouring smaller cabinets and using multiples to get SPLs up.
Chris
Old 9th July 2018, 02:24 PM   #12
angelodj is offline angelodj
Hoffman's iron law.
Chris
I did not understand, better more small boxes?
Old 9th July 2018, 02:41 PM   #13
chris661's Avatar
That's how I prefer to roll.
I have 8x 15"s in small ported boxes tuned to 40Hz. I can use one for smaller gigs, and just bring more according to how loud it needs to be.
Others prefer just using one or two big cabinets.
Chris
Old 9th July 2018, 03:32 PM   #14
ok! What is your tappedhorn 15?
I'm sorry if I ask questions being in Italy I often need to understand well in English
Old 9th July 2018, 05:31 PM   #15
chris661's Avatar
Teeny tiny PA 15" subwoofer
It's more like a ported box. ~95dB at 1w input.
Ciao,
Chris
Old 9th July 2018, 07:31 PM   #16
hi, I saw the link, I do not see the plans though! but going back I can not see the images that are no longer present
Old 9th July 2018, 08:50 PM   #17
MMM...
Mikesound Letohrad - zvuka? Jaroslav Mikyska ? Mike 2003-2009 Ozvu?ov?n? kulturn?ch akc?.
Old 9th July 2018, 09:05 PM   #18
Brian Steele is offline Brian Steele  Grenada
Originally Posted by Xoc1 View Post
Multiples of the tapped horn will not show the gains in low end performance that the bandpass horns will when used in groups.
I've often heard this repeated, but I haven't seen any empirical tests to back it up, and the sims suggest otherwise. Granted, the change is not as large as say that for a FLH (likely due to the difference in mouth sizes), but the sims do suggest that there should be a difference.
www.diysubwoofers.org
Old 9th July 2018, 09:11 PM   #19
Hmmm... I'm skeptical that boxes that small can do 40 Hz ~ 125 Hz at 100dB/1W/1M using an 8 ohm driver. I'd want to see some actual measurements that back that spec up.
Old 9th July 2018, 10:59 PM   #20
Cabinet beyma sb15
real efficiency tham 15 martinssonHide this!Advertise here!
2 tham 15 or? instead of the w-bin angelodj Subwoofers 12 18th June 2018 09:44 PM
THAM 15 or this QSC Sub? nunyagd Subwoofers 27 27th October 2016 03:55 PM
Martinsson's TPAM10HTL subwoofer FranciscoPerez Subwoofers 3 6th October 2015 05:30 PM
THAM 12 and THAM 15 cabinets for sale servojohn Swap Meet 0 17th February 2015 02:50 PM
