First diy build
First diy build
Old 9th July 2018, 12:17 AM   #11
The Fisherman is offline The Fisherman  United States
Yea sorry about that. I tried loading the image several times in all differant orientations, always came out the same way in the preview. I'm not very Internet savvy! I can build or fix just about anything if I can touch it or draw it. This is the first forum I have ever posted in and I'm 50. Up until a couple years ago I was either at work or on the water.
Thanks very much for the feedback.
MF
Old 9th July 2018, 12:17 AM   #12
Galu is offline Galu  Scotland
Originally Posted by The Fisherman View Post
Is port top or bottom better?
Will make no difference, could even be situated on the back.
Old 9th July 2018, 12:19 AM   #13
Yes dcs385-4
Old 9th July 2018, 12:24 AM   #14
This is the first forum I have ever posted in.
MF
I'm new to this posting lark myself, and thank you for your feedback!
I'm hoping the cabinet designer buffs might step in now.
Old 9th July 2018, 01:01 AM   #15
cochleus is offline cochleus  United States
cochleus's Avatar
Hi, it looks like your well on your way.
One suggestion though...Baltic Birch is a way more suitable material for sub cab walls and bracing instead of 3/4" MDF.
Old 9th July 2018, 07:53 AM   #16
hollowboy is offline hollowboy  Australia
Those dimensions & port look fine to me. I suggest you make it slightly oversize, to allow enough volume for some internal bracing - but don't sweat about getting it exact.
You can tweak the response after it is built by changing the port's length, and by trying the sub in different room positions. Room placement makes more difference than getting the box size 'perfect'.
People usually recommend ply because it is a lot stiffer than MDF (for the same weight). For a sub, a rigid box = good. Some people go to crazy extremes
Baltic Birch is the default 'good' ply, but if you can source an equivalent (e.g. if you can get marine ply at mate's rates), go for it. If weight doesn't matter, you can just use more (thicker) MDF, or whatever else is cheap & easy.
This edit signature thingy is seriously hard to find
Old 9th July 2018, 11:52 PM   #17
Thanks every one for your input. I will begin shortly and will post as I go.
MF
Old 9th July 2018, 11:57 PM   #18
Looking forward to following your progress.
Let those woodworking skills loose!
Old 12th July 2018, 07:26 PM   #19
FYI in searching for three or four B baltic birch ply I came across an alternative. Sorry if this is already know. It's called appleply. Looks as good and maybe better that BB. USA product!
MF
Old 15th July 2018, 05:17 PM   #20
GM is offline GM  United States
GM's Avatar
Right, with similar specs along with no-void marine grade; the traditional triumvirate of desirable speaker building plywood panels with Bamboo a step up.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
First diy buildHide this!Advertise here!
Transmission Line Speaker Build using Alpair 7.3 speakers, first build. vishalk Full Range 123 29th March 2017 12:22 AM
Super Squirrel Monkey - First from-scratch tube amp build, first guitar amp build ericj Instruments and Amps 32 5th April 2016 10:28 PM
question:How to build How to build music player with tda1543 use rapspberry pi B+? gary095315 Digital Source 1 30th December 2015 07:35 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
