Dipole Bass Recomendations
Old 4th July 2018, 02:59 AM   #11
outfoxhyperion is offline outfoxhyperion
Just to confirm we're all thinking the same thing when we say "W-Frame," I'm hoping to configure the woofers in a very similar manner to the W style seen in versions of Seigfried Linkwitz' Orion speakers.
Old 4th July 2018, 02:32 PM   #12
bentoronto is offline bentoronto  Canada
Originally Posted by outfoxhyperion View Post
...the required volume to get the kind of performance I was looking for was enormous (like 28 ft3 per driver)...
Odd, the rest of us seem to do fine with less than 6 cu feet. You aren't demanding profound bass and bit of boost where the sealed box perks up a bit south of 50 Hz would sound just right.
Or you could run a sealed box sim and get a screwy result that seems to generally be around 2 cu feet, plus lots of EQ.
With a crossover below maybe 140 Hz, and going with DSP as you plan, you need only one good sub to qualify for great sound quality.
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 5th July 2018, 12:23 PM   #13
It's very possible that the sims I was using weren't giving me great data, I was just using online calculators as I don't own any software. I'm likely to end up trying it both ways, but I'm going to start with the W-frame due to the semi-dipolar response as I said above. If I'm not a fan of how that sounds, I'll likely build a sealed box. In that case, it'll be two drivers per side, so that should be somewhere around ~12 cuft, if I take the numbers you suggest?
Old 8th July 2018, 05:51 AM   #14
Calvin is offline Calvin  Germany
Calvin's Avatar
since size is an issue, I'd think of an Ripole-style dipole.
It's by far the smallest and reduces the driver's fs maximal.
There are quite a lot of 15" Pro drivers around with fs between 35-40Hz, medium Qts and long stroke capability.
These drivers are built to take some abuse and don't cost too much.
With a set of TSPs as above, fs could drop to 25-20Hz without requiring too much equalization/amp power.
The Beyma 15LX60 could be an example for this kind of driver.
Keep in mind though that with the small folded dipoles the upper bandwidth is limited.
I'd say not much more than 100-150Hz for a 15" design.
jauu
Calvin
Old 9th July 2018, 03:25 PM   #15
Hi Calvin,
Thanks for the advice. One of the parameters for this project though was to use these 10" buyout woofers, but I might try one of those 15" Ripoles in the future...
As an update on the project, I've built and tested one of the W-frame enclosures, and it did pretty well down to 30 Hz with a little bit of extension below that. No measurement tools available as of now, so all this is based just on what I heard. It wasn't loud, but then again I was running it full range just on the left channel of an A/V receiver, ran out of amp volume control but didn't have any clipping or gain control so I think that's just an issue of low levels. Sounded like there was a little bit of resonance around 200ish Hz, but I plan on crossing lower than that anyway. So far, so good.
Dipole Bass RecomendationsHide this!Advertise here!
Dipole/OB bass -small dipole woofers vs bigger woofers on same baffle wonderfulaudio Subwoofers 10 5th May 2018 01:25 PM
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 07:42 AM
dipole stereo bass? xstephanx Subwoofers 63 1st June 2006 12:19 PM
Some dipole bass measurements John Sheerin Multi-Way 19 3rd January 2005 06:48 AM
dipole bass help amo Multi-Way 11 17th September 2003 06:06 AM
Resources saved on this page: MySQL 68.42%
