New Dayton Neo 15" I'm very excited about
Just saw this on Parts Express: Dayton Audio PN395-8 15" NEO Series Pro Woofer with 4" Voice Coil 8 Ohm
  • High efficiency (97dB SPL at 2.83V/m) for amazing output capability
  • 4" diameter inside/outside wound copper voice coil on glass fiber former
  • Large copper cap for inductance control and low distortion
  • Powerful FEA optimized Neodymium motor system (Bl over 25 TM)
  • Generous 6.5 mm of Xmax with 48 mm peak-to-peak excursion before damage
  • Durable fiberglass reinforced ribbed paper cone for rigidity and natural sound
Product Specifications
  • Nominal Diameter 15"
  • Power Handling (RMS) 800 Watts
  • Power Handling (max) 1,600 Watts
  • Impedance 8 ohms
  • Frequency Response 40 to 3,500 Hz
  • Sensitivity 97.3 dB 2.83V/1m
  • Voice Coil Diameter 4"
Thiele-Small Parameters
  • Resonant Frequency (Fs)44.1 Hz
  • DC Resistance (Re)5.5 ohms
  • Voice Coil Inductance (Le)2.2 mH
  • Mechanical Q (Qms)8.82
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)3.42 ft.³
  • Mechanical Compliance of Suspension (Cms)0.09 mm/N
  • BL Product (BL)25.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)150.0g
  • Maximum Linear Excursion (Xmax)6.5 mm
  • Surface Area of Cone (Sd)890.3 cm²
Looking to update my PAL12s that are loaded with Eminence LAB12Cs to something more compact in a 15, like an SS15 of CUBO15s. At that price I'm building 4
- can see why you're excited - make a light weight - well braced Jim Bell SS15
"20.75 lb" doesn't sound right - it oughta be lighter (?)
oops - forgot to enter 2.2mH Le - But that looks great too !
correct Le "bold"
2pi
I'm no good with t-line (GM and others are good) but would think a tapped pipe would make it usable to 30Hz or below (?)
(if not played real loud)
putting it in a 250 liter airspace. one - fold negatively tapered pipe in a corner shows
(but 160 liters tuned to ~24Hz - Not Shown - looks like a better tradeoff)
maybe Brian would suggest a 30Hz OD-TL if the excursion is good enough for you
I'm considering an SS15, or a modtfied one, or maybe the 15" version of Art's Keystone sub.
The new 15" I'm excited about is the Radian 2216. OMG:
8 ohms
1400w RMS:
Sensitivity: 101 dB ! - unless they’re lying.
Power Compression: No idea.
Fs 36.8 Hz
Freq: 28Hz - 2K
BL 34.229
Qms 2.72
Qts .219
Vas 4.51 ft^3
Xmax 21.3 !
14 lbs !!!!!!!!!!!!!!!
Dennis @ Radian says it’s a 15” cone with an 18” motor.
Frequency response is insanely flat (if they aren’t lying) to almost 30 Hz, and only 5 dB down at 20 Hz..
Maybe a 1 dB peak from 45 - 60 Hz.
- this graph was made with a 4.6 cu. ft. Vented Cabinet Tuned To 36Hz.
One possible downside is the price: $750. Still .......
