Where did the >50 EBP = OK for vented heuristic come from?
Old 13th June 2018, 10:49 PM   #1
altie is offline altie
Default Where did the >50 EBP = OK for vented heuristic come from?
Advice seems to be unanimous across the web that an EBP of 50 is an appropriate cutoff where <50 means only suitable for sealed while >50 is OK for ported/vented, or maybe at higher points even for horn application.
Where did this originally come from, or how was it derived? It doesn't seem obvious at all to me that this is a better way to determine whether you can go ported than just eyeballing Qts (lower is better) and BL (higher is better). Ideas?
Old 16th June 2018, 01:42 AM   #2
davewantsmoore is offline davewantsmoore  Australia
EBP = Fs/Q .... so kinda the same thing.
Old 16th June 2018, 02:48 AM   #3
wg_ski is offline wg_ski  United States
If the Q is too high (EBP too low) the response gets peaky regardless of what you do with the dimensions. Or it will get so large that it's not worth it to put in a cheap driver which typically can't put out much SPL before something hits the stops.
Where did the &gt;50 EBP = OK for vented heuristic come from?Hide this!Advertise here!
Help w/vented box? Richidoo Subwoofers 62 25th August 2015 02:14 PM
Help with vented 2 way design h5tuu Multi-Way 2 5th October 2013 02:36 AM
Vented or TL pipo Multi-Way 7 7th November 2001 06:11 AM
Vented or TL pipo Multi-Way 2 7th November 2001 05:12 AM
