Old 28th January 2012, 01:44 PM   #311
Originally Posted by bjorno View Post
Ops, should be ~10 Hz
b
Hi b
just one more question ! what would be the diameter and the length of the Pvc port pipe ?
Abhi
Old 28th January 2012, 03:27 PM   #312
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by abhihemu View Post
Hi b
Abhi
The internal port is L= 24 cm, Internal diameter = 10 cm.
b
Old 29th January 2012, 07:15 AM   #313
b
Hi b,
i am attaching the plan suggested by you.
Abhi
Old 30th January 2012, 07:56 PM   #314
Hi b,
Abhi
Hi Abhi,
Sorry, almost missed your answer...
You've got it right!
Note: The internal panel = 1B in your drawing has a thickness of 21 mm.. as I can see :If using 18 mm here too would not alter the performance of this box ..
You need also to internally brace the box ,random irregularly cross-bracing should work just fine.
I would spray-glue a~ 1/4" wool felt internally ,at least on the insides of the rear panels.. Covering all internal panels would too be a good idea as a lot of energy is transfered to the wood..
You really don't want to hear any localization cues from a sub like this one. I would definitively place this sub as close to a corner as possible.. with the driver and port preferably oriented close to the floor level.
b
Old 31st January 2012, 05:47 AM   #315
Thanks b
I'll take care of bracings and be using glue at proper places..
Abhi
Old 31st January 2012, 11:15 PM   #316
Really looking to see how this turns out!
Old 15th February 2012, 06:34 PM   #317
freddi is offline freddi  United States
freddi's Avatar
excellent looking design Bjono!
Old 16th February 2012, 12:40 PM   #318
Hi freddi,
Thank you freddie
I noticed that in post #307:Picture #1 is posted by a mistake.
Here is the correct one:
b
File Type: jpg 0_Peerless-of-India_10inch-small-DBR_Sections.JPG (401.9 KB, 56 views)
any 1 eva tryed using 'phones + sub for infra? Helix Everything Else 5 7th July 2011 11:13 PM
capacitor coupled vs. direct coupled ouput hugobross Solid State 11 21st January 2011 01:56 AM
infra-red detectors pfcs49 Parts 6 7th March 2008 04:07 AM
what the max Air velocity of bass reflex port? Audist Multi-Way 4 7th February 2005 08:43 PM
Remote control fo creative infra 18X ?? hannes86 Digital Source 2 12th November 2004 05:14 AM
Page generated in 0.09775 seconds (76.11% PHP - 23.89% MySQL) with 11 queries
