Tapped horn: How much does the driver's rear output load the horn?
Old 16th April 2018, 05:26 AM   #1
wonderfulaudio is offline wonderfulaudio  India
Default Tapped horn: How much does the driver's rear output load the horn?
In a tapped horn, the wave from the rear of the driver (at mouth) is used to 'load' the horn (1/4 wl).
1) Given that the driver is also near mouth, what portion of the driver's rear output goes in to resonate the horn and what portion goes out without going in?
2) Does driver placement more towards the mouth 'load' less and vice versa?
Thanks and Regards,
WonderfulAudio
Old 16th April 2018, 02:41 PM   #2
Rademakers is offline Rademakers  Netherlands
1) You can simulate the effect of the tapped horn configuration by comparing it with the output of a rear loaded horn. This (in part) would show the effectiveness of the second halve of the cone on the output.
2) I do think that the placement/ location of the driver in the horn mouth influences the tapped horn effectiveness. However I'm not aware of any research into this.
Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 16th April 2018, 04:31 PM   #3
just a guy is offline just a guy  Canada
You can simulate this effect by looking at the output at one side of the driver only, you can get an idea by simulting each driver position alone and view the throat side tap and the mouth side tap separately. You will find that the throat side tap does the bulk of the work and the mouth side tap does almost nothing, providing only a few harmonic spikes that fill in the hole in response a regular transmission line would have.
Old 19th April 2018, 02:44 AM   #4
j.michael droke is offline j.michael droke  United States
Default TH, driver mouth side
Hi there: Somewhere here in DIYAUDIO posts, Tom Danley stated what JAG writes above: "providing only a few harmonic spikes that fill in the hole in response a regular transmission line would have." In spite of advanced age, if I remember correctly, TD mentioned 2nd harmonic dip. ...regards, Michael
Old 19th April 2018, 03:41 AM   #5
lholland is offline lholland  United States
www.audiomatica.us
lholland's Avatar
Put on your seatbelt:
2012 Danley Sound Labs Whitepaper
2006 PSW Forum Post
Tapped horn: How much does the driver's rear output load the horn?Hide this!Advertise here!
Tapped Horn with rear chamber GjMR Full Range 1 22nd February 2018 02:01 AM
what driver for tapped horn? vadi Subwoofers 11 12th April 2010 07:22 PM
Single Driver Front and Rear Horn johninCR Full Range 17 14th March 2005 01:53 PM
