Want to build a TL subwoofer - driver advice needed
Old 27th March 2018, 05:57 AM   #51
GM is offline GM  United States
GM's Avatar
A simple 62 cm offset driver driver pipe with a Ap = Sd x 294 cm [~237 L] lightly stuffed full length to 'taste' or accept HR's 668 g of polyfil [~25 Hz Fp] is good for a < 100 Hz/4th order XO. Different tapers or even a MLTL didn't help much due to its high inductance.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th July 2018, 07:02 PM   #52
GASCo is offline GASCo  United States
GASCo's Avatar
To the OP, what did you end up going with?
Old 18th July 2018, 06:56 PM   #53
solid7 is offline solid7  United States
I ended up building a sealed subwoofer, with what I already have. The T/L may happen later. But my life is a bit too busy now for another project. LOL
Want to build a TL subwoofer - driver advice neededHide this!Advertise here!
Subwoofer driver advice needed: 10" - 12" driver for 88L (3.1CuFt) enclosure ctmorsejr Subwoofers 11 23rd May 2016 04:03 PM
Advice Needed For a Second DIY Subwoofer petercool1992 Subwoofers 9 30th August 2013 07:20 PM
Subwoofer build advice. turdburst Subwoofers 6 2nd June 2012 01:23 PM
Advice needed on new 6L6 ro 6V6 SE or SET build GloBug Tubes / Valves 39 23rd November 2011 04:22 PM
First subwoofer- advice needed please :) olly-s Subwoofers 12 5th May 2008 09:38 PM
Resources saved on this page: MySQL 70.00% / PHP 32.10%
