Limiter database for Subwoofers
Old 9th February 2018, 12:09 PM   #1
LORDSANSUI is offline LORDSANSUI  Brazil
Default Limiter database for Subwoofers
Hi everyone,
I'm searching for informations about limiters and few good things were found, in additional I noted that the user experience is really important when setting the parameters to maximize the system efficiency and keep things protected at the same time, so I'm proposing a thread as database to collect as much as possible user's informations that could be used by everybody.
Limiter data
Enclosure type: TH, FLH, Vented, Sealed, etc (hugh influence at drivers heat transfer)
Driver Supplier: B&C, 18sound, Eminance, etc
Driver Model: XXXX
Driver Power Rate: YYYY [W] , continuous, peak, etc
RMS Limiter Applyed: Z % of Power Rate
Peak Limiter Applyed: W % of Power Rate
Notes: General comments as if the current amp is underpowered so it defines the peak limiter at your application, etc
Limiter database for SubwoofersHide this!Advertise here!
Transistor Database Soundork Parts 2 7th May 2016 01:00 AM
F/S: Subwoofers and More Subwoofers (Car Audio Mostly) MiniVanMan Swap Meet 0 27th October 2014 02:36 AM
Knobs Database A3rd.Zero Parts 11 15th November 2004 08:31 AM
Project database michael Multi-Way 5 27th February 2004 03:55 PM
Multisim2001 database Bjarne Software Tools 0 14th February 2003 02:40 PM
