1 Sub or 2 for X-Over at 80hz
Old 31st January 2018, 02:57 AM   #1
tribute is offline tribute  Australia
Default 1 Sub or 2 for X-Over at 80hz
Hi, I want to add a sub or maybe two to my system crossing over a say 80hz. At this frequency can you still define stereo. If not I should be able to get away with one sub, however if you can still hear stereo then I guess I need 2. Cheers
Old 31st January 2018, 03:03 AM   #2
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Older recordings might have drums, bass, guitar, vocals etc. on separate tracks.
(Dusty Springfield - Son of a Preacher Man, The Mamas & The Papas - California Dreaming, etc. )
Today most engineers will mono mix at the low freqs.
Either 2 subs if you want true stereo or you sum the l/r signals via DSP or some circuit for a single mono sub.
Old 1st February 2018, 12:00 AM   #3
mordikai is offline mordikai  United States
Send a message via Yahoo to mordikai
I always do stereo (or more often 4 subs), just makes me feel better.
Old 1st February 2018, 01:39 AM   #4
jplesset is offline jplesset  United States
I have 4 subs, and have tested to see if I can hear stereo vs mono feed. With a 24db/oct crossover, I can not tell. With 12db crossover, I can localize the woofers easily.
Old 4th February 2018, 07:07 PM   #5
bentoronto is offline bentoronto  Canada
+1
But the subs have to be pretty clean or they might divulge their location with any slope.
Datapoint: lived for decades with a Klipschorn bass corner horn in several homes... which, of course, needs to be in a corner, often far from main speakers. Never a localization issue on music, even with a 130 Hz Xover.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 4th February 2018, 07:14 PM   #6
googlyone is offline googlyone  Australia
a decent crossover slope at 80Hz will not be able to be located.
- I have used 24dB/octave and can sit right next to the sub in a nearfield monitor setup without noting it is at my left knee.
- The sub DOES need to have no rattles, port noise etc.
- I have not tried this at 12dB/octave, but reckon you would be very close to being totally insensitive.
- I mono the sub outputs from an active crossover in this application.
As a general rule I load in a pair of subs if I have the choice. More a matter ot power handling and headroom than absolute necessity. I still don't run them stereo, as there is no point.
Old 4th February 2018, 08:48 PM   #7
silverprout is offline silverprout  France
silverprout's Avatar
Originally Posted by googlyone View Post
a decent crossover slope at 80Hz will not be able to be located..
...but your waveform will be totally distorded.
Things I Should Have Learned In School (But Probably Didn't)
Old 4th February 2018, 10:16 PM   #8
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Any particular reason?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 5th February 2018, 12:24 AM   #9
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I always listen to stereo mixed to mono on my amp.
It saves setting up two amps.
No crossovers just a full range speaker.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 5th February 2018, 06:03 AM   #10
ASP LR filter
1 Sub or 2 for X-Over at 80hzHide this!Advertise here!
How do I make a LP at 80hz lorienblack Subwoofers 13 14th July 2013 04:29 AM
Bad sub response in 50-80hz region. buck1138 Subwoofers 8 9th August 2012 10:35 PM
80Hz and up fullrange cabinet? kristleifur Full Range 12 7th August 2007 11:31 AM
Dual subs below 80Hz- what should I be hearing? darkmoebius Subwoofers 8 17th July 2005 04:38 AM
80Hz hypex Edgarhorn Rocky Multi-Way 54 12th June 2004 03:17 AM
