Is speaker blown?
Is speaker blown?
Old 6th February 2018, 09:33 PM   #11
LORDSANSUI is offline LORDSANSUI  Brazil
Looks like t-nuts has the power to really mess up things. I had my first and unique experience at the project SS15MOD.
Fortunately my T-nuts were not pulling out, I bind them but as side effect when the screw is not properly aligned with the t-nut the joint will not be able to fastening, the screw point face will block itself forcing you to unscrew all and start again. Just after finish my project I remember about one common solution often used at vehicle industry, it may help many folks here and for sure I will use in the next project.
To avoid problems with t-nuts we should used screw with special point, it was initially designed to improve automated process, it has a kind of cone, or a big chamfer (if you prefer) that will guide the screw to the proper female thread and auto centering. Below you can find a sketch and a real image about it as example. It ca be found with different heads and different necks and I think it can fix issues related to t-nuts.
Direct image link: https://s17.postimg.org/xb4ut51rz/Screw.png
Direct image link: https://s17.postimg.org/yq6fhvq0f/P_20180206_155908.jpg
Direct image link: https://s17.postimg.org/q7wzdkm2n/P_20180206_155919.jpg
Old 6th February 2018, 11:09 PM   #12
MAAC0 is offline MAAC0  Portugal
One of my Behringer B115D sounded rattling. The woofer magnet on one side was loose. There was a tiny "paper sheet thickness" space between the gasket and the magnet. I've put a heavy load on the back side and glued all with Araldite. Working fine now.
Is speaker blown?Hide this!Advertise here!
Speaker sounds blown RubberSalt Car Audio 60 12th December 2011 11:21 PM
Blown speaker josb52 Multi-Way 5 11th October 2010 09:12 PM
Speaker sounds blown...but isn't bereanbill Tubes / Valves 16 17th June 2009 04:29 PM
Blown speaker (coil?) anything I can do? aletheian Multi-Way 7 4th December 2005 10:54 PM
blown speaker in a quadbox tivruski Multi-Way 0 4th November 2005 10:11 AM
