TPQWR with GAS Comp15D1
the resonator should behave like it is 49,5 cm deep. Not 43 cm
I guess the driver placement and the large magnet is to blame for some of this.
I guess the front resonator behaves like a frequency and phase dependent variable length resonator then. This explains a lot!
Thanks for the help on my way to twist my head around this design!! :)
This argues for the split path layout, since you excite the front resonator symmetrically and loose less resonator-length to the tapped pipe exits.
Now I will try this exercise with my split path symmetrical ROAR12. At least it has a better known driver with more trustworthy specs then this monster GAS Comp15.
Johannes
