Powered sub troubleshooting
Old 1st January 2018, 03:40 PM   #1
duder1982 is offline duder1982  United States
duder1982's Avatar
Default Powered sub troubleshooting
The sub in question is a Velodyne servo F-1800rII. Every since I have own this sub, I have used it for lfe in my tv room, it would make a popping sound when low frequencies play. I figured this was due to pushing the sub past it's capabilities. Recently it has developed a hum, which may be due to a bad cable.
I would like to verify my assumptions as I would like to make the decision to either replace the driver or the amp. If my assumptions are correct, then it may be best to sell the sub as a whole to someone who is looking for a sub just for music.
My thoughts are to try the sub in a 2 channel system to see how it performs. This could eliminate a lot of extra un needed work. If the problems exist, I would remove the driver and run some test tones to see if the driver itself is performing like it should. This should narrow it down to just the plate amp.
Any thoughts?
If I cant build it or fix it I really dont want it.
Powered sub troubleshootingHide this!Advertise here!
help troubleshooting samson db500A powered 15 main Basscrime PA Systems 15 18th November 2016 04:47 PM
Troubleshooting amplifier in powered monitor putting out DC to driver. nerogtr Solid State 2 7th March 2015 01:43 AM
Troubleshooting sound issues with battery-powered outdoor PA sharevari PA Systems 4 17th June 2012 04:58 PM
Troubleshooting a music powered LED light box. Wagge Everything Else 2 5th January 2012 11:56 PM
Yamaha powered mixer, need help troubleshooting netwerx1 Instruments and Amps 1 8th April 2010 02:39 AM
