Old 5th April 2004, 08:52 PM   #1
lawbadman's Avatar
Default 6.5 inch Subwoofer
Hey Guys,
Does anyone know where on the internet I can find a decent 6.5 inch 4 ohm subwoofer for an Altec Lansing ACS56?
Old 5th April 2004, 09:05 PM   #2
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
I would look into that high excursion 6.5 sub from tang band.
Old 6th April 2004, 12:58 AM   #3
lawbadman's Avatar
What about this:
http://www.partsexpress.com/pe/pshow...number=290-352
Will it be able to handle the power, as it seems a bit cheap. Should I go for better quality?
Old 6th April 2004, 01:00 AM   #4
Budget?
And I wouldn't worry about power handling; the ACS56 doesn't have a very beefy power supply.
Old 6th April 2004, 01:03 AM   #5
http://www.partsexpress.com/pe/pshow...=295-305&DID=7
Old 6th April 2004, 01:38 AM   #6
lawbadman's Avatar
Hey 454Casull, thanks for the replies.
The DAYTON 6-1/2" woofer wont work too well as I need a 4 ohm woofer to get the max output from the amp (the original speaker is 4 ohms too). I searched all of partsexpress and all I could not find anything so great. Althought I could have missed something.
Any more web sites I could check?
I am willing to spend up to $50.
Old 6th April 2004, 04:02 AM   #7
BAM is offline BAM
Send a message via AIM to BAM
When the new Tang Band comes out, it will have a 4-ohm impedance. I guess you'll have to be a bit patient, as they're still trying to make it reliably. At least that's the buzz I've heard - perhaps TB is having some issues making the drivers.
Old 6th April 2004, 04:24 AM   #8
Speakerholic
Cal Weldon's Avatar
Default Re: 6.5 inch Subwoofer
Originally posted by lawbadman
[B 6.5 inch 4 ohm subwoofer ACS56? [/B]
What ever happened to the word woofer?
We're talking 15 cm here.
Cal
Old 6th April 2004, 06:36 AM   #9
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
HOw many woofers does it take to complete a woofing woofer. ?
Old 6th April 2004, 10:40 AM   #10
The sub is question appears to be a small reflex design ?
If so the Goldwood would not work well.
Can you give an estimate of internal volume and port dimensions ?
sreten.
Subwoofer down to 10Hz and only 1 inch deep! ashok Subwoofers 7 6th May 2009 04:36 AM
Hartley 18 Inch Subwoofer For Sale thetubeguy1954 Swap Meet 10 22nd April 2009 12:47 PM
FS: 10 inch subwoofer driver mudihan Swap Meet 3 9th August 2008 09:47 PM
Audiobahn 34 Inch Subwoofer - Anyone ever build a box for one? tomtomjr Car Audio 26 24th April 2008 04:07 AM
search 15 inch Pro subwoofer ? nickthevoice Subwoofers 42 17th April 2008 11:24 AM
Page generated in 0.09883 seconds (77.15% PHP - 22.85% MySQL) with 11 queries
