Subwoofer in series
Subwoofer in series
Old 3rd January 2018, 04:49 PM   #21
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
It sounds like he's describing something on that continuum, yes
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 3rd January 2018, 10:51 PM   #22
Lunchietey is offline Lunchietey  Australia
The only real use of isobaric woofers are when using drivers that need huge enclosures or when you have a very specific maximum box size.
If amplifier power is unlimited, and the cost of extra drivers doesn't bother you, it can be a way to get what is effectively a huge box into a small space(for example two isobaric 18's into 2.5 cuft sealed or similar)
If space is no issue, there's not a lot of REAL advantages. Even though you may have slightly reduced thd, you can achieve the same or similar reductions in distortion without losing output if you have more space (ppsl, tapped horn etc)
Isobaric loading was more popular when drivers needed huge enclosures but had high sensitivity and power was very expensive.
Subwoofer in seriesHide this!Advertise here!
Inductor series sestistance, effect on Qts, 2 identical drivers in series shmb Multi-Way 6 11th September 2015 04:54 PM
FS: Velodyne SPL Series II Subwoofer Plate Amplifier beaux1977 Swap Meet 3 17th June 2013 07:50 PM
Orion Cobalt Series 10 Inch 400-Watt Subwoofer - ORN CO104S silly123 Subwoofers 5 5th March 2013 01:50 PM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 10 3rd August 2012 07:32 AM
Building a subwoofer using a TOA 900 series amp scott_jcp Subwoofers 2 24th February 2005 02:33 PM
