Subwoofer in series
Subwoofer in series
Old 29th December 2017, 10:20 PM   #11
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
So basically I get the output of one woofer by using 2 and a smaller enclosure?
Old 29th December 2017, 10:27 PM   #12
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
In a nutshell , half the size enclosure than one driver, the most space saving way is "clamshell" (more shells please )
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 29th December 2017, 10:32 PM   #13
"Clamshell" is what I would have done, cone to cone.
But now...
it is a waste of resources (2nd woofer) I think.
I was hoping for more advantages than just a smaller enclosure.
Old 29th December 2017, 10:35 PM   #14
Yes, I think so too, and this does seem to be the modern consensus, perhaps when drivers weren't as good the cancellation of non linearities was a bigger advantage. Also with a clamshell it's the back of the cone that you hear.....doesn't seem right
Old 29th December 2017, 11:21 PM   #15
Joshcpct is offline Joshcpct  Germany
Hi all. A friend of mine tested it. The cancellation only affects even harmonics.
It can be up to 20dB lower which is magnificent.
But, as u noted, poor efficiency. Using both for output, cuts excursions half and reduces uneven harmonics. At the end both outputting was better.
But here’s the thing:
You can still use isobaric advantages & principle while doubling efficiency at the same time.
Simply turn one woofer outwards and one backwards installed, separate from each other, both outputting, and connect out of phase. That also causes both producing even harmonics out of phase to each other while the input signal is played in phase.
The only drawback is the 2 different positions (distance between both membranes) are not canceling out so much. But its still 10dB. Cuts distortion to third of percentage. Better than nothing. If you manage to get them even closer (like in an ripole alike slot) you still get the 20dB, AND your smaller enclosure / or deeper Fs due to slot airmass load). Im only refering to the frontslot of ripole. Coz running the back open will obviously skyrocket the excursion and distortion even worse so keep the back closed (or Reflex, Horn whatever).
As you can assume this is only nice for subs.
But im currently planning some tests for midrange on horndrivers.
Cheers
Josh
Old 29th December 2017, 11:28 PM   #16
Interesting.
Thanks for the info.
I would put them in a 6th order bp.
Old 29th December 2017, 11:42 PM   #17
wilson benesch speakers - chimera wilson benesch 0a - Hifishock
Old 30th December 2017, 12:26 AM   #18
Josh, I think I understand what you are saying, but if I'm right, there are no isobaric principles involved in that set up, some distortion cancellation yes.
Old 30th December 2017, 01:00 AM   #19
GM is offline GM  United States
GM's Avatar
Specs say [2] isobaric bass units: http://wilson-benesch.com/downloads/...nge_Manual.pdf
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 3rd January 2018, 06:37 AM   #20
MemX is offline MemX  United Kingdom
Cheers
Josh
Is that a PPSL?
Subwoofer in seriesHide this!Advertise here!
Inductor series sestistance, effect on Qts, 2 identical drivers in series shmb Multi-Way 6 11th September 2015 04:54 PM
FS: Velodyne SPL Series II Subwoofer Plate Amplifier beaux1977 Swap Meet 3 17th June 2013 07:50 PM
Orion Cobalt Series 10 Inch 400-Watt Subwoofer - ORN CO104S silly123 Subwoofers 5 5th March 2013 01:50 PM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 10 3rd August 2012 07:32 AM
Building a subwoofer using a TOA 900 series amp scott_jcp Subwoofers 2 24th February 2005 02:33 PM
