First DIY Project Subwoofer
Old 24th April 2004, 12:35 AM   #41
ozynigma is offline ozynigma  Australia
Send a message via Yahoo to ozynigma
moving_electron,
Problem was I was a couple of millimetres short, otherwise I would have sanded off the extra with my orbital sander.
Next time I will cut the sheets better to start with and also design for routed joins on each edge for a more positive connection.
Inside each join is braced by 35mm x 35mm timber, screwed and glued so the sub cabinet is certainly stiff and strong enough.
I used 18mm MDF, but on advice from the speaker supplier I doubled this to 36mm for the front panel.
Howard
Old 24th April 2004, 01:08 AM   #42
moving_electron is offline moving_electron  United States
moving_electron's Avatar
Location: Where the rain does fall but the trees grow tall
Originally posted by ozynigma
moving_electron,
I always seem to end up with a bit of a gap when I go to put on the last side (usually this is the baffel). One of the edges is lower in a spot and I have a gap in some spot. I used to try to even it up by hand sanding (hard), then went to gluing in a thin shim to even it out (easier).
Recently I just decided to use a gap filling glue on the last panel and it all worked just fine. I used the newish Elmers glue version of Gorilla glue.
Weird glue as it is smelly, sticks to your hands, expands and is activated with water.
Great stuff for this purpose though.
First DIY Project SubwooferHide this!Advertise here!
DIY Subwoofer Project whubbard Subwoofers 9 22nd February 2008 11:18 PM
subwoofer project, which subwoofer? Davlaf Subwoofers 12 9th November 2006 03:59 AM
New ESP subwoofer project. ssanmor Subwoofers 0 3rd February 2006 06:47 AM
Subwoofer Project Dazza Subwoofers 0 20th July 2005 08:22 AM
My new subwoofer project kinser Subwoofers 8 29th January 2005 05:45 PM
Copyright ©1999-2017 diyAudio
