Voice Coil Repair Volt Woofer
Old 5th December 2017, 10:52 AM   #1
hugo stiglitz is offline hugo stiglitz  Germany
Default Voice Coil Repair Volt Woofer
Hi there,
I have got a pair of 12" Volt Woofers out of a PMC MB2S.
They are not exactly Volt RV3143 but similar but modified by PMC.
However they got fried as a signal too hot was sent into the speakers.
So my general question is: is it possible to repair/replace voice coils from woofers?
And if so, what would that cost?
Of course, I also texted PMC already but they directly suggested a complete driver replacement which would be very epensive.
Old 5th December 2017, 11:04 AM   #2
pieter t is offline pieter t  Netherlands
Don't know if there are companies in Germany who repair/replace voice coils.
Here in the Netherlands there are companies doing this.
A more detailed description of the voice coil (material; diameter; height; number of layers) would be needed to get a reasonable idea of cost.
Old 5th December 2017, 11:10 AM   #3
Boden is offline Boden  Netherlands
Look and ask here: http://www.total-speaker-repair.nl/
Ernst Schouten, the owner, has experience second to none. Very few loudspeakers , including all sorts of exotics, and so called "specials" or modified drivers , have not passed his hands over the years. Look on the site for pictures of VC repairs.
Good Luck,
Eelco
Old 5th December 2017, 11:27 AM   #4
thank you for the tip! good adress...
at least I should be possible to get a pair of new voice coils from PMC.
they just need to be mounted then..
will get in touch with total-speakers-repair
Old 5th December 2017, 11:30 AM   #5
Manufacturers occasionally charge ridiculous prices for original replacement parts.
So, do yourself a favour and check&shop pricing firstly.
Old 5th December 2017, 11:46 AM   #6
It's important that new voicecoils are the same as the originals; otherwise you'd have a different woofer spec wise.
I know that Ernst buys most of his voicecoils elsewhere because it is not economic to wind them all himself; that might be different in this case.
Just ask him; I am pretty confident that he comes up with a solution.
Old 5th December 2017, 11:48 AM   #7
Hm.. the problem is, that I cannot find any info about PMC 12" driver used in the MB2S .. nor do I find any info about its voice-coil.
It's a bit problematic as those must be the exact same voice coils, otherwise I will get problems with the passive crossovers used.
This is a passive system.. so specs shoudln't change.
Old 5th December 2017, 02:32 PM   #8
kaputt is offline kaputt  Germany
kaputt's Avatar
Take out the voice coil, measure dimensions of the coil former, measure diameter of wire and count the number of turns.
Oh boy, I live in the snake oil thread...
Old 5th December 2017, 03:13 PM   #9
Most of the claims about so called "modified" drivers are BS anyway and are often nothing else than a marketing trick in disguise to justify outragious pricing way above the standard item. If the Rdc of the so called modified driver is the same as the standard and the magnet is also the same, you can bet it is similar.
Old 5th December 2017, 03:13 PM   #10
Und dann kann ich mir die Kugel geben
Voice Coil Repair Volt WooferHide this!Advertise here!
Voice coil repair question Fastmerc Full Range 2 8th May 2017 09:54 AM
NAD 7250PE Repair From Driving a Shorted Voice Coil? MrRobogoat Solid State 2 27th March 2014 06:48 AM
DIY Tweeter Voice Coil Repair Mush Multi-Way 3 27th May 2013 11:07 AM
Speaker Repair Voice Coil Spider DreadPirate Multi-Way 3 8th January 2007 08:51 AM
measurement TS in a double voice coil woofer hiendaudio Multi-Way 2 3rd February 2004 05:31 PM
