Voice Coil Repair Volt Woofer
Old 5th December 2017, 03:16 PM   #11
hugo stiglitz is offline hugo stiglitz  Germany
Originally Posted by Boden View Post
Most of the claims about so called "modified" drivers are BS anyway and are often nothing else than a marketing trick in disguise to justify outragious pricing way above the standard item. If the Rdc of the so called modified driver is the same as the standard and the magnet is also the same, you can bet it is similar.
Well, I hope so.. at least PMC claims to modified magnet and voice coil and use a special coating to the cone ..
At least the coating can be seen in real life.. PMC drivers shine, Volts are matte
Old 5th December 2017, 03:22 PM   #12
pieter t is offline pieter t  Netherlands
Agree with the modify BS; the standard item however is already outrageously priced :
Volt RV3143 12” RADIAL TECHNOLOGY Bass Mid Driver
Old 5th December 2017, 03:25 PM   #13
yes exactly.. PMC's "modified" version of this comes at 700€ per unit !
Old 5th December 2017, 03:46 PM   #14
Mmm, the original PMC monitor is specified being 4 ohm.
The Volt woofer is 8 or 16 ohm
Old 5th December 2017, 05:21 PM   #15
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
at least I should be possible to get a pair of new voice coils from PMC.
they just need to be mounted then..
1) PMC will NOT sell you a pair of spare Voice Coils for very good reason.
It being that you canīt "just" unscrew the old voice coil as you might do with, say, a car spark plug and replace it yourself and screw in a new one.
Car engines and most mechanical things in general are *designed* to be disassembled, bad parts pulled , new ones mounted and the whole machine reassembled, often set up/adjusted/calibrated .... NOT so with speakers.
2) Speakers have incredibly strict space, weight and precision constraints, so the only assembly method is *gluing* parts together .... modern adhesives being insoluble/unmeltable types (epoxy or some kind of cyanoacrilate) so in general repair involves cutting the whole moving assembly away, meaning: voice coil - spider - cone - dome - tinsel wires , *junking* it , scratching old adhesive remains and cone - suspension bits away from the frame, and reassembling speaker with all new parts and using centering jigs plus being careful with voice coil vertical position so it sits in space (itīs floating and mobile) in the proper position.
So much for "just replacing a pair coils".
Given the extra work involved, repairing a speaker is more expensive than just building it for the first time, it takes double or more time .
The Netherlands shop mentioned looks qualified and should do a good job.
And since you send botgh, matching will be guaranteed.
Canīt put a price for somebody elseīs job but might be about half of new unit cost.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 5th December 2017, 07:15 PM   #16
Okay, I see.. the PMC woofers go to the trash ..
Old 5th December 2017, 07:18 PM   #17
Why not contact Total Speaker Repair before doing that?
Ernst is rather creative.
Old 5th December 2017, 08:45 PM   #18
kaputt is offline kaputt  Germany
kaputt's Avatar
Or any other reconing place. For example Klangmeister in Lemgo.
Oh boy, I live in the snake oil thread...
Old 7th December 2017, 12:39 AM   #19
Djim is offline Djim  Netherlands
Manufacturers occasionally charge ridiculous prices for original replacement parts.
Hi Boden,
In the case of studio reference monitors there is a reason why replacements are expensive.
Usually the drivers are hand selected based on individual measurements for each driver to keep the differences between the left and right monitor within a certain frame (+/- 1.5dB for instance). It is common practice to replace both drivers for left and right monitor if only one is damaged, of course, if the manufacturer does provide hand selected drivers. Some manufacturers have a database of all their produced monitors (based on the serial numbers) and if a client asks for a replacement they can select one, based on their database info. In such case only the damaged driver needs to be replaced.
VC repairing or a 'simple' replacement from any source, is not a good idea if you want to keep the 'reference' from the manufacturer.
Djim
Old 7th December 2017, 10:47 AM   #20
Boden is offline Boden  Netherlands
@Hugo; do not give up!
@Djim,
The is is not a simple replacement from any source; this is simply making an exact1:1 copy of the original. That is a very simple job, although manufacturers would like us to believe it is complex. Would you agree that in case the new VC is electrically identical to the original, the driver's parameters and characteristics remain the same (= ceteris paribus)? Volt drivers have certainly seen the TSR workshop before. Ernst knows his stuff, believe me.
BTW I am in no way commercially linked to TSR, but have been co-operating with Ernst the past. Always been impressed with has ingenuity an knowledge about speaker components. And yes, I have been assembling drivers myself.
BTW II. Already around 1980 Dick Pierce wrote an article in SB about VC dimensioning. He provided a spreadsheet, from which to calculate VC parameters, based on wire thickness, number of turns, lengtht and dia of the vc.
Eelco
Voice Coil Repair Volt WooferHide this!Advertise here!
Voice coil repair question Fastmerc Full Range 2 8th May 2017 09:54 AM
NAD 7250PE Repair From Driving a Shorted Voice Coil? MrRobogoat Solid State 2 27th March 2014 06:48 AM
DIY Tweeter Voice Coil Repair Mush Multi-Way 3 27th May 2013 11:07 AM
Speaker Repair Voice Coil Spider DreadPirate Multi-Way 3 8th January 2007 08:51 AM
measurement TS in a double voice coil woofer hiendaudio Multi-Way 2 3rd February 2004 05:31 PM
