Subwoofer Design like Fan without Sound
Old 5th December 2017, 11:45 AM   #11
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Good idea, and you could put it on the ceiling out of the way, why has nobody thought of this before?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 5th December 2017, 11:45 AM   #12
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by scottjoplin View Post
...like a 2 stroke engine, one piston and two valves ducted so they vent 180 degrees apart
Erm, a two stroke engine in it's original layout doesn't feature any valves at all?!?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 5th December 2017, 11:46 AM   #13
Reed valves
Old 5th December 2017, 11:57 AM   #14
Yes, but this means a more advanced construction over the original Nikolaus Otto idea.
Best regards!
Old 5th December 2017, 11:58 AM   #15
But he want's a high performance fan
Old 5th December 2017, 12:27 PM   #16
...and has a really elaborate, sophisticated idea to achieve this, har har.
Best regards!
Old 5th December 2017, 12:37 PM   #17
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
This is a very silly idea. If you want a low noise fan then buy a low noise fan!
But as a mad DIY project I like the concept.
Using both sides of the speaker in separate chambers makes sense and the reed valves should work.
But the valves will introduce physical noise and harmonics to the output flow so there will not be a clean 30hz.
Also sensitivity has little to do with SPL - Displacement of air has.
50 or 60 hz will be cheaper - just use a mains transformer.
Old 5th December 2017, 02:48 PM   #18
TNT is online now TNT  Sweden
Rotary Subwoofer - Worlds Lowest Freq Subwoofer - YouTube
More distortion to the people!
Old 5th December 2017, 03:11 PM   #19
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi All,
FYI: A weird attempt? Check my Calculations:
b
Old 5th December 2017, 03:37 PM   #20
Hi again.. Forgot to divide xmax with sqrt(2)..This makes the Maximum Volume Flow to ~ 75 m^3/h
b
Subwoofer Design like Fan without SoundHide this!Advertise here!
Intermittent subwoofer sound dannyjmf Subwoofers 2 14th November 2015 03:27 PM
Why does this subwoofer sound right? argonrepublic Subwoofers 5 20th February 2013 07:42 PM
Sound Design, a new book on innovative and interesting ideas in speaker design. Studio Au Multi-Way 3 8th April 2012 08:46 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
No Sound from subwoofer htgeek Car Audio 7 12th April 2005 06:49 AM
