Optimising Bass Microphone Servo control
Old 6th December 2017, 09:25 PM   #11
weltersys is online now weltersys  United States
weltersys's Avatar
Originally Posted by wgh52 View Post
Maybe a possible trick here would be to filter the Mic-signal with a low pass equivalent to the 180 Hz cross-over low-pass, so the feedback circuit does not "hear" the mid-driver taking over at 180 Hz? Would that be "a huge overkill" or wrong or counterproductive or a potential improvement?
The mic works with the inverse-distance law, each doubling of distance looses 6 dB level. At "ground zero" the woofer level is likely far louder at the acoustic crossover than the relatively distant mid-driver. If you lower the mic low pass, it won't "hear" harmonic distortion as well, so can't correct it as effectively.
Old 7th December 2017, 12:04 AM   #12
bentoronto is offline bentoronto  Canada
The 4n7 is clearly operating in the audio range. As you enlarge the operating band, you risk entering a zone of instability. Manufacturers of motional feedback systems live in fear of instability and blown drivers: otherwise they would have gone to a smaller filter cap too. Not saying what a DIYer should do with a closely monitored home system, just want to be careful.
This may sound heretical, but multi-speaker FR charts can be misleading due to phase/interference effects and in relation to the REW mic and musical content. In other words, pure swept sine wave results may not correspond to the audible loudness on complex sounds. So the middle FR with the dip may sound better than the 2n2 on the right.
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 12th December 2017, 02:22 PM   #13
Sonce is offline Sonce  Macedonia
Originally Posted by bentoronto View Post
Using the figure-8 reception of that mic (once I paid 50-cents for that kind of capsule),
That kind of electret mic has omnidirectional (kugel) characteristic.
Old 15th December 2017, 09:58 PM   #14
bolserst is offline bolserst  United States
bolserst's Avatar
… not really sure if the above solution as such is "state of the art", accommodating for all the possible or necessary servo optimizations, i.e. can achieve what is possible. Therefore would like to gather input for servo bass improvement of my speakers, including how I would confirm by (acoustic and oscilloscope) measurements.
Looks like you have an interesting speaker in your hands
To determine what B&M achieved in the circuit and what optimization is possible, you would need to measure the open loop response. To do this, you need to break the feedback loop. The most convenient place to do this is the connection between the preamp and power amp as shown in the attached figure by the red X. Input a low level test signal into the power amp(10 – 50mVrms) from measurement software(ARTA, REW, etc) and measure the electrical frequency/phase response coming out of the preamp where you broke the loop. Dividing this by the input signal will gives the open loop response, which tells you how much feedback is being used and what the gain and phase margin is.
While you have the feedback loop broken, you might also measure the acoustic output of woofers while using the same direct input into the power amp. This will show you what the natural response of the woofer/cabinet is before feedback is applied.
…There are a few details I don't understand about the circuit myself, though, e.g. what is the function of the 4n7 C across the microphone terminals in the actual circuit?
The 4n7 capacitors across the microphones form a first order low pass filter with R157, rolling off the feedback signal above about 1kHz.
You mention seeing a 6dB change in woofer level when changing the values of these capacitors. I don’t understand why that would be unless one of the 2 microphone connections was bad before or after the change. (ie factor of 2 = 6dB) Where are the two capacitors physically located? And how are the connections made between mic, capacitor, and preamp board?
Old 15th December 2017, 11:53 PM   #15
I'd add - to the always super help from Bolserst - you might also chart the feedback signal itself. Like most of the signal of interest, it is relative to whatever is also motivating the system.
B.
Optimising Bass Microphone Servo controlHide this!Advertise here!
Infinity Irs servo control rvito Multi-Way 0 11th May 2017 02:16 PM
Simple Servo Control KatieandDad Everything Else 0 2nd January 2014 01:19 PM
DIY Servo Sub- need help with control circuit flyingtele Subwoofers 1 28th January 2013 07:57 PM
Does anybody know how to use the MCU to control the CD servo? zhangzq71 Digital Source 0 19th December 2008 03:52 AM
Servo Bass mrfeedback Subwoofers 32 2nd January 2006 07:51 PM
