Dual Tang Band 6.5" BR
Old 3rd December 2017, 12:41 PM   #11
grahamgraham is online now grahamgraham  United Kingdom
grahamgraham's Avatar
Thanks, is it a case of up to an inch of adjustment on fine tuning? Obviously I won't know until its measured but do you have any idea what range it may effect? Thanks again.
Originally Posted by Brian Steele View Post
You should be fine with a right-angled bend and a particle speed of 12.5m/s
At 22m/s, you are going to see some vent compression effects. This may not be readily audible however, unless perhaps you're playing test tones.
The proximity of the inside end of the vent to the nearby walls will lower the effective resonance frequency a bit. Be prepared to measure Fb and to trim the vent if necessary.
Old 3rd December 2017, 12:43 PM   #12
Yes it does! I am just getting the hang of bass reflex at the moment. I'm On my fourth build. Would this attempting too much to adapt that design?
It looks very compact and girlfriend dictates I can do what I want it just can't be ridiculous. lol
That's an interesting design. The penultimate section of the vent seems to be a bit larger than required, but I'll bet that's not only to house the amp, but perhaps to act as a small resonance chamber to damp organ-pipe effects caused by the long vent.
Old 3rd December 2017, 12:50 PM   #13
Yeah, they look really interesting, thanks! My girlfriend might not approve. Compact is an element.it has to be under 60cm tall to fit in.
The anarchy tapped horn looks very interesting. I will compare my drivers with the Anacrhy drivers. Do you think there will be the need for a lot of adjustment ind esign to accomodate my drivers?
Originally Posted by straight8s View Post
Those are a great value subs and very versatile, cubes or miniature tapped horns, just one plays quite loud and deep and give bigger subs a run. For HT and music consider anarchy boxes. Anarchy Tapped Horn DIY Sound Group Search mad mike anarchy sub there are more helpful plans out there.
Its littlemike, I saved the trouble LittleMike's Anarchy Tapped Horn - Home Theater Forum and Systems - HomeTheaterShack.com
There is 3 versions inside projects Volvotreter Homepage
19hz dual 6" The Tangband 19Hz Tapped Horn Volvotreter Homepage
Old 3rd December 2017, 12:51 PM   #14
Silly me, it is for the TangBand!
Old 3rd December 2017, 06:18 PM   #15
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi All,
FYI:
b
File Type: jpg 75mm-Diam.Pipe-with-90-degree-Bend.JPG (321.2 KB, 188 views)
Old 3rd December 2017, 07:07 PM   #16
LightBit is online now LightBit  Slovenia
LightBit's Avatar
Originally Posted by grahamgraham View Post
For a shorter port I could use a 75mm port diameter but the port velocity shoots up to 22ms. Is this way too high?
Don't forget, it is 22ms at full power. Driver might be limited by Xmax.
You can try my SpeakerSim, which simulates port velocity at maximal power (according to Xmax).
SpeakerSim - speaker simulation software
Old 3rd December 2017, 09:36 PM   #17
Brian Steele is offline Brian Steele  Grenada
It will push Fb lower, how much lower its hard to say. Just make the last section removable so you can easily trim it.
www.diysubwoofers.org
Old 4th December 2017, 01:37 AM   #18
Jerms is offline Jerms  United Kingdom
W6 sub - Techtalk Speaker Building, Audio, Video Discussion Forum
That build might offer some ideas. Lots of info and some measurements further down.
J.
Old 4th December 2017, 05:58 AM   #19
Thanks, yes very detailed.
I'm starting to wonder from other peoples projects if I really need two dual subs since this driver is a little weapon. I have the TB 5.25" driver in a BR box for my kitchen and it is might big for its size but I want subs that I don't need to push to hard.
J.
Old 4th December 2017, 06:10 AM   #20
This project looks very tempting to me. I think I will build my dual sub but maybe later one try these cabinets for a stereo config.
The Tangband 38Hz Tapped Horn – Volvotreter Homepage
My queries in regards to this are as follows:
He mentions "Note that the design includes the use of 4,7mh coils to even out the response. They are wound from 1,32mm dia. copper wire and have a Rdc of 0,26 ohm."
How are these implemented and what is he smoothing out?
The response looks funky after 100hz, I usually cross my subs over at 120hz for a bit more upper thump in my system. Is this no-mans land for the way I would like to use them?
Also, are the drivers trapped in the design once they are sealed up? I'd like to have flexibility to move drivers from different cabs in the future?
Dual Tang Band 6.5" BRHide this!Advertise here!
Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendation permo Subwoofers 216 9th June 2018 08:57 PM
Tang Band W4 Bamboo and tiny tang band tweeter? Jeremy067390 Full Range 2 30th March 2017 02:11 AM
WTD: Tang Band W3-1878 and Tang Band W4-1337SDF smallangryboy Swap Meet 3 10th September 2013 06:49 PM
dual 4" tang band bamboo in box norman bates Swap Meet 1 15th March 2010 10:53 AM
Questions about the Tang Band W8Q-1071F 8"x12" Subwoofer MyNameIsJake Subwoofers 4 26th January 2008 02:57 AM
