dual boxes or one big box?
Old 2nd December 2017, 11:22 AM   #21
ctrlx is offline ctrlx  United Kingdom
here's a test you can try if you currently have two drivers in one box - feed them with a low frequency (10Hz) and observe what the drivers are doing.
Old 2nd December 2017, 11:55 AM   #22
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Not a sub, but this is how I did it for my MTM.
I figured that each driver being in it's own volume removed the possibility of any modulation of the cones from each other (from the inside) and that this is diy so if you can why not, as there didn't really seem to be any downside to doing it. I also figured that it meant that I didn't need any other form of bracing
One possible disadvantage would be the closer proximity of panels to each driver that the partition(s) introduces.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 9th December 2017, 01:15 AM   #23
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
2 enclosures.
Placement, stability, easier to transport/hide, sound, ... plus If you go ported and kill one driver you still have one full functioning unit left.
For a compromise maybe 2 chambers in one enclosure.
2 speakers playing in one chamber will always sound "bad". They will never be exactly the same and therefore there will be cancellations and phase problems plus distortion from reflecting waves inside the chamber reflecting back unto the cones. Damping will help but anyway it is not optimal.
Old 9th December 2017, 01:20 AM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Not my experience. My sealed push-push woofers set a high standard of quality.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th December 2017, 02:12 AM   #25
Maybe the TSP are very close.
And even then seperate enclosures will still sound better.
Old 9th December 2017, 02:46 AM   #26
frugal-phile(tm)
planet10's Avatar
I beg to disagree… push-push woofers largely takes the box and reaction forces out of the equation.
dave
Old 9th December 2017, 11:14 AM   #27
Now I get it. Drivers are opposed to each other. Well then it could work.
Sorry for my ignorance.
Old 24th February 2018, 07:55 PM   #28
spandrel is offline spandrel  United Kingdom
I seem to remember that putting two speakers in one cabinet increases the cutoff frequency, presuming the same size cabinet. They are in acoustic series, is that right? And acoustic parallel lowers the cutoff (face to face, cross wired). I've lost all my speaker design stuff, lent it out to someone, so apologies if this makes no sense.
Old 24th February 2018, 10:05 PM   #29
frugal-phile(tm)
planet10's Avatar
That is true. Exactly like putting one driver in an enclosure half the size.
dave
dual boxes or one big box?Hide this!Advertise here!
Dual boxes with 8" (TB 1772 and 740Q), sealed and Linkwitz perceval Full Range 18 5th August 2016 04:08 PM
:-( my (fe126en) FrugalHorn mk3 boxes sound wore than small boxes Ensoniq Full Range 31 15th December 2015 10:25 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 03:17 PM
Fostex FF125WK Speaker Boxes / Planet 10 FF125WK Drivers/Boxes jonparkhurst Swap Meet 2 23rd August 2013 06:19 PM
Dual-Chamber Vented Boxes BAM Multi-Way 9 2nd July 2004 01:37 PM
